S197 Mustang Forum - S197Forum.com
Go Back   S197 Mustang Forum - S197Forum.com > Mustang s197 Tech Forums > 2015+ S550 Mustang 2.3L Ecoboost Tech
Reply
Thread Tools Display Modes
Old 07-22-2015, 01:22 AM   #1
Ecoboost15
Ecoboost15 is an unknown quantity at this point
Default Check Engine: P04DB
I have a 2015 Ecoboost mustang. My check engine light randomly comes on and the ECU code is P04DB. I am unsure as to what caused this issue.
Installed on car:
Cold air in take.
Inter cooler.
Axel back exhaust.
dyno comp tune.
I did have a aftermarket downpipe on the car but it didn't have enough back pressure and it cause my car to smoke pretty bad so I put the stock one back on.
Anyone think they know what this code means and could help would be awesome!
Thanks,
Brandon
Ecoboost15 is offline   Reply With Quote
Old 07-22-2015, 01:47 AM   #2
Redline727
"I wanna go fast!"
Redline727's Avatar
Redline727 is an unknown quantity at this point
Default
According to what I have researched that is a generic code for crankcase ventilation disconnected.
Start with tracing your intake install.
__________________
2015 Oxford White Ford Mustang GT Premium with Performance Package
2013 Performance White Ford Mustang GT Premium 6MT (SOLD)
Redline727 is offline   Reply With Quote
Old 07-28-2015, 03:34 PM   #3
Ecoboost15
Default
Ok awesome thank you! I did forget to mention I do have an oil catch can system installed as well. So I wonder if that could be part of the reason there is a code?
Old 07-28-2015, 05:05 PM   #4
Redline727
"I wanna go fast!"
Redline727's Avatar
Default
Yes! The catch can is tied into your crank case vent system. On most V8's it's a loop system. Air gets pulled in the crankcase from the air intake tube on bank 1 driver side. Then pulled out from bank 2 by the intake manifold. The valve is on bank 2. You put the catch can in between the valve and the intake manifold to not pull vapor into the manifold causing oiley vapor to screw up fuel mixture and sit in the manifold. So start looking there.
__________________
Old 08-01-2015, 05:57 PM   #5
Redline727
"I wanna go fast!"
Redline727's Avatar
Default
Did you find your culprit?
__________________
Old 08-05-2015, 11:49 AM   #6
Ecoboost15
Default
Awesome thank you for the help man! I have not had a chance to check it out yet but I will be sure to look for this.
Old 08-05-2015, 11:53 AM   #7
Ecoboost15
Default
Would you happen to know if someone is able to install subs in the 15 mustang? I am curious because Ford designed the car to play the sound of an engine through the speakers to make it sound mean and not just a 4 cylinder turbo car. I am not sure if there is a wire to cut to disable this or how to bypass this setup so the sound would not be played through the subs.
I have tried to look for youtube videos but have not had any luck at finding anyone who has done this. Any ideas?
Old 08-05-2015, 12:54 PM   #8
Ecoboost15
Default
Redline- thanks for the info, I do however have the 4cyl ecoboost motor, any clue on that set up? I donít remember there being any sensors close to the connections but I may have missed something.
Old 08-05-2015, 01:12 PM   #9
Redline727
"I wanna go fast!"
Redline727's Avatar
Default
I don't know specifically on the ecoboost engine. But through work I have access to a website that gives us repair instructions for pretty much every car. We use it to work on our non BMW used cars we take in on trade. I'll see if I can find something with a diagram on the ecoboosts PCV system. It's a great program I'm sure it will have what you need to trace the system. I use it all the time for my car.
__________________
Old 08-05-2015, 01:15 PM   #10
Ecoboost15
Default
Awesome thank you so much man! I really appreciate all the help!
Old 08-05-2015, 01:22 PM   #11
Redline727
"I wanna go fast!"
Redline727's Avatar
Default
Excuse me while I put my foot in my mouth. Looks like they don't have shit in the database for the ecoboost yet...see how everything is grayed out? I get the message that no data is available yet. I'm sure if I had the motor in front of me I could figure it out...let me try a good old Google Search and see what I come up with.
Click the image to open in full size.
__________________
Old 08-05-2015, 01:41 PM   #12
Ecoboost15
Default
Dang man, thank you so much for looking though! Let me know if you can find something on google. The only thing I really came across was the code for trucks and such, nothing specific to the ecoboost mustang.
Old 08-05-2015, 02:54 PM   #13
Redline727
"I wanna go fast!"
Redline727's Avatar
Default
Which catch can system do you have? I found a couple different ones. The two I looked at hook up on completely different sides of the engine. UPR shows it between the line coming off the throttle body and then add a vacuum to the turbo inlet tube then the line going to the oil pan...Mishimoto however goes inbetween the line coming off the crank case to the intake manifold on the driver side of the motor, which to me seems like where the pcv is...so what style do you use so I know what side of the motor to tell you where to look??? Haha. UPR's design I'm not familiar with. Mishimoto seems more traditional.
__________________
Old 08-05-2015, 03:07 PM   #14
Redline727
"I wanna go fast!"
Redline727's Avatar
Default
This is how UPR explains reason for using the passenger side:
2015 Ecoboost Mustang PCV Function and Flow Explained
We have recently switched to a Single Valve Kit after extensive testing. The results were consistent every time unlike the ecoboost trucks with the larger 3.5L,*these motors have a much more efficient PCV system that the system does not require a dual valve setup or clean side separator. The oily oil we are collecting
is off the heavy load on the passenger side of the ecoboost motor.
The system has a one directional flow that scavenges the clean air from the passenger side pickup on the intake tube right before the turbo and then get drawn through the crankcase and out the driver side swivel connection right above the starter coming out of the engine block. Then gets hooked to the throttle body to*
draw through the intake and get burned clean in the combustion chamber as per EPA regulations.
Testing was over 3000 extremely hard miles and testing it in every situation from cruising to flat out everyday of testing. The passenger side yielded great results and the driver side stayed bone dry.*
Ultimately the design of this setup would need twin catch cans if you wanted to install a catch can on the passenger side on the passenger side hose to not disrupt the airflow and proper crank case evacuation. The dual valve basically locks the system and does not allow for fresh air correctly because the system is unlike the 3.5L ecoboost platform.
So it pulls fresh air from the turbo inlet into the crank case. Out a valve above the starter through the throttle body into the intake manifold burning the vapor through the engine as per federal regulations. Then there is on on the driver side connected directly between the crank case and intake manifold. From what I read UPR states they have collected most oil on the passenger side not the driver side how Mishimoto has their setup. So basically whatever side you have yours on you need to go back and check all your connections.
__________________
Old 08-05-2015, 03:09 PM   #15
Redline727
"I wanna go fast!"
Redline727's Avatar
Default
I'm willing to bet if you have UPR's style and for the code you have it's going to be somewhere probably at the throttle body connection.
__________________
Old 08-05-2015, 04:05 PM   #16
Ecoboost15
Default
It's a dual valve UPR oil catch can. I am going to get a new connection and hopefully it will fix the issue!
Old 05-04-2016, 02:38 PM   #17
Bavalos1
Bavalos1 is an unknown quantity at this point
Default
Where you able to fix your problem, I have the same issue no catch can tho
Bavalos1 is offline   Reply With Quote
Old 09-15-2016, 10:50 AM   #18
shadow
shadow is an unknown quantity at this point
Default Error Code P04DB
Quote:
I have same issue. Only 2 items installed
AIRAID 450-330
Other was Y pipe with
Thrush 17650 Welded Muffler.
I had these item on for under 1 year no problems with it until yesterday.
I will on the weekend remove the intake box and reinstall again to see if that fixes it. Will let you know.
shadow is offline   Reply With Quote
Old 10-12-2016, 09:32 PM   #19
shadow
Default Update on Error Code
AIRAID 450-330
So I didn't do anything the code went away on its own. I wanted to remove the intake and reinstall again but the code didn't show anymore.
Sorry this didn't help but it's what happen.
Old 04-15-2017, 09:54 AM   #20
86GT351
86GT351 is an unknown quantity at this point
Default
What system are you using?
86GT351 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Ad Management plugin by RedTyger
