S197 Mustang Forum - S197Forum.com
Go Back   S197 Mustang Forum - S197Forum.com > Mustang s197 Tech Forums > Vendor New Product Releases
Vendor New Product Releases Check out what's new from our vendors!
Reply
Thread Tools Display Modes
Old 11-09-2016, 06:12 PM   #1
BMR Suspension
Official Site Vendor
BMR Suspension is an unknown quantity at this point
Talking BMR Suspension New Product - Rod End S197 Upper Control Arm - UTCA038
BMR Suspension Rod End Adjustable Upper Control Arm for 2011-2014 Mustang
UTCA038
Launching harder, reducing wheel hop, and adding cornering consistency to your 2011-2014 Ford Mustang is easy with a rod end upper control arm from BMR Suspension. The stock control arm with soft rubber bushings deflects under load and absorbs power instead of transferring it to the tires. BMRs rod end, on-car adjustable tubular upper control arm for S197 Mustangs (UTCA038) is manufactured from heavy-duty CNC-machined 1 5/8 inch, 0.250-inch wall threaded steel tube. The telescoping center adjuster is CNC-machined from chrome-moly steel with rolled threads for the ultimate in strength and durability. This design gives you an incredibly strong control arm that greatly improves performance. BMRs 1-inch rod ends offer high levels of strength and articulation, far exceeding the small rods ends used by other suspension companies. BMR Suspension designed the UTCA038 to work well in street performance, drag race, and handling applications. The UTCA038s heavy-duty construction eliminates control arm flex, giving you much improved repeatability on the street, starting line, or in the corners. The adjustability allows you to dial in pinion angle for correct driveline geometry and reduced NVH. BMRs rod ends offers tons of articulation for great handling, while offering more than enough strength to stand up to high loads of any performance environment. These are the perfect upgrade for the enthusiast looking for max performance at an affordable price. When performance is a must, rely on BMR Suspension! Installation time is only 2-3 hours. Available in black hammertone or red powdercoat.
To preview all of BMRs high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Avenue, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
Click the image to open in full size.
BMR Suspension is offline   Reply With Quote
Old 11-13-2016, 05:04 PM   #2
Falkwa
Falkwa is an unknown quantity at this point
Default
why is this one cheaper then some of the others you offer? im in the market for once since i umm snapped mine in half last night.
__________________
'06 GT 5psd, '13 CJ springs, Full Spherical ass end set up,Tuned by Randy Carter, 4.10s,TrueTrac, Long Tubes O/R H, Airaid "Race" intake, Cammed, FRPP intake, ect ect ect.... Jeremy is gonna end up taking alot of my monies.
Falkwa is offline   Reply With Quote
Old 11-15-2016, 07:03 AM   #4
Gabe
Whippled Coyote
Gabe's Avatar
Gabe is an unknown quantity at this point
Default
That thing looks awesome!
Hey on a somewhat related subject, what size are the adjusting/jam nuts and the adjuster for the adjustable poly-end 11-14 UCA?
__________________
My Mustang: '13 GT Track Pk, Recaros, Koni/Steeda/JLT, BMR Watts Link & UCA, 2.3L Whipple, 608rwhp/517rwtq
Fiancee's toy: '08 GT500, Koni/Steeda/FRPP/JLT, BMR Watts Link, '13 TVS, 656rwhp/661rwtq
My blog: Gabe's Garage
Gabe is offline   Reply With Quote
Old 11-15-2016, 11:28 AM   #5
BMR Tech 2
Kelly's Lackey
BMR Tech 2's Avatar
BMR Tech 2 is an unknown quantity at this point
Default
Thanks, Gabe!
The jam nuts and adjuster are 1.5". I usually use a 1.5" crowfoot wrench to adjust them. It's a lot easier than trying to get a full size wrench in there AND it's a lot cheaper to buy one if you don't already have a 1.5" wrench.
https://www.summitracing.com/parts/s...FdcagQodOXsFFw
BMR Tech 2 is offline   Reply With Quote
Old 11-15-2016, 12:12 PM   #6
Gabe
Whippled Coyote
Gabe's Avatar
Default
OK cool that's what I was finding on some older threads on the internet, but wanted to make sure.
I found a 1.5" wrench on Amazon that's only about 8" long and it only has one open end, it's straight at the other end.
I was gonna grab that but I'll look into the crowfoot option.
Thanks again.
__________________
Old 11-20-2016, 07:54 PM   #8
06silverbullet
06silverbullet is an unknown quantity at this point
Default
will this fit 05-10 vehicles?
__________________
06 GT: N/A 315rwhp/335rwtq tuned at RET
06silverbullet is offline   Reply With Quote
Old 11-20-2016, 08:13 PM   #9
Wes06
Wes06's Avatar
Wes06 is an unknown quantity at this point
Default
The UCA made for 11+ will fit ours, as long as you use a 11+ UCA mount.
In the newer years the UCA is a little bit longer and the earlier style isnt long enough for correct geometry
__________________
Quote:
Originally Posted by skwerl View Post
You're doing it wrong. I have no idea what you're doing wrong but it's wrong.
My rear opening isn't near as large as Cam's but it will still hold a quart size bottle of brake fluid.
Wes06 is offline   Reply With Quote
Old 11-21-2016, 11:46 AM   #10
BMR Tech 2
Kelly's Lackey
BMR Tech 2's Avatar
Default
Quote:
Yes, as long as you order the 11-14 mount as well (UCM002). You will also need to order the 11+ UCA bolt from Ford. This is the bolt that goes under the seat. Part number: W714389-S439
Here is a thread I put together that explains the differences between the two:
http://www.s197forum.com/forum/showthread.php?t=128140
Old 01-03-2017, 01:20 AM   #11
NickD87
NickD87's Avatar
NickD87 is an unknown quantity at this point
Default
I am assuming strength is the advantage of this over the other Spherical Bearing versions.
Between the two on a mainly street car that also like sub 1.5 60's which is better for the street and lower NVH?
__________________
NickD87 is offline   Reply With Quote
Old 01-03-2017, 10:43 AM   #12
BMR Tech 2
Kelly's Lackey
BMR Tech 2's Avatar
Default
NVH will be about the same between all the bearing uppers. We introduced this arm because we wanted something that was a little more wallet friendly for our customers. Our UTCA033 is the baddest UCA on the market, and it's price reflects that. Not everyone that needs a bearing upper wants to or can afford to grab the UTCA033.
Old 01-10-2017, 02:25 AM   #13
don-ohio
don-ohio is an unknown quantity at this point
Default
BMR Tech,when you folks gonna make an aftermarket support brace for the 05-09 and later Mustang Convertibles? I was fortunate here and found 2 in great condition, but it would be nice for everyone if you had some available.
I've seen your weld-on braces,but I wanted bolt-on like Ford originals. don-ohio (:^)
don-ohio is offline   Reply With Quote
Old 01-12-2017, 10:15 AM   #14
BMR Tech 2
Kelly's Lackey
BMR Tech 2's Avatar
Default
I've been talking about that with the owner for a while. I'll just keep bugging him and hopefully we'll be able to make something happen!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Ad Management plugin by RedTyger
