Hello,
this is my first post here so let me start with a big thank you for all the thing I've learned just lurking on this forum.
Going back to my problem, I have a 2007 GT. When I bought it, it has the airbag light always on. The previous owner swapped the original front seats with airbags with 2006 version without airbag. To exacerbate the problem, the passenger side seat wiring harness of a 2006 model is different from a 2007 one, different connectors!
Anyway, changed the wiring harness with the correct one. Installed two Airbag Delete Resistors and off it goes the airbag light. Everything seems fine!
The other day, while driving around, I noticed the airbag light on again. If I turn off and back on the engine the airbag light goes off after the canonical 6 seconds, no blinking no nothing. After 15-20 minutes it starts blinking (LTC code 34) than stays on.
Now, I know the meaning of the LTC code 34, a problem with passenger side seat belt pretensioner. But why it jumps out after 20 minutes? Is there a particular reason? I always though the RCM performs a full self-test on the SRS at startup so I assume I should have the airbag light turning on immediately not after 20 minutes.
Any ideas?
Any ideas?
