Bburns4667
- Joined
- May 28, 2017
- Posts
- 20
- Reaction score
- 1
So this just started a few days ago
5speed tranny bmr lower control relocation brackets and bmr drag springs.
Car is turbo makes 550whp.
I made a third gear pull and while decelerating a bad vibration happened and reverberated through the shifter really loud.
I drove next day and nothing out of the ordinary. It drive fine out of boost just slowly accelerating. In second and third when you hit boost and it access fast is has a vibration I can feel in the pedals and hear in the shifter. I looked at u joints they seem ok. Tranny mount is ok. Motor mounts look decent I will be changing them out soon as my k member shows up.
Only thin I can think of is the spec clutch that has 20k miles on her that was slipping on the dyno is maybe doing it. Like I said it doesn't do it under normal driving. I have a twin disk ready to go in but I'd like to pinpoint the problem before I have the car apart so I can fix all at once. Any thoughts?
Oh harmonic balancer looks ok engine revs in neutral fine
