Pop sound on initial acceleration
tightwhite08
Upon initial acceleration from a dead stop there is a "pop" sound from the rear (passenger side from what I can tell but not 100%). It's a single sound and only starting from a dead stop.
I am a few hundred miles into post new suspension (eibach pro kit and adj poly/rod bmr rear control arms) so could the suspension have "settled" causing it? Didn't happen pre new suspension and again not for the first 200 miles or so after. Everything was torqued/lubed/pinion angle/etc.
Did a search on all the 05-09 rear end rattles but didn't find anything on this specific noise.
Curious as to your thoughts.
check the ploy bushings and sphericals first
BMR Tech 2
Kelly's Replacement Lackey
Tampa, FL
^This
Check to make sure you haven't popped a Poly bushing.
a deformed or split bushing
over torquing the hardware
Many times u can see the split from the threads I've seen here.
