max2000jp
I have an oil leak and the likely culprit seems to be the driver side valve cover gasket as I see oil on the power steering pump below it. The oil is then making it's way down the power steering hose and leaking on the ground. Anyone ever run into an issue with leaking valve cover gaskets? I searched and didn't find much. I figured I'd ask before heading to Ford to buy a new gasket. Thanks!
