3v Turbo Cams
Turbotungsten
I have a set of custom 3V turbo cams that are ground by Comp. The specs are:
Duration at .050 226 Int 231 Exh
Lift 501 int 476 exh
lobe sep angle 115.5
These cams make great power, spool my turbo quickly, and have a mild but noticeable idle. They are still in the car, so I would need to take them out if they sell. They have about 9000 miles on the cams. $625 Shipped
Turbotungsten
Better pic of spec card
Here's a better pic of the spec card
Turbotungsten
Bump. I never had any bites, but wasn't dead set on selling them. My interest has peaked a bit. Lowering price to $550 shipped
Turbotungsten
They are out of the car now and setting on my shelf. $400 shipped. I also have stock cams. and will sell for 150 shipped. I will get picks of both sets soon.
blacks197
Albuquerque,NM
Do you still have the turbo cams? What else is needed to run these? Just limiters/lockouts or new springs also. Thanks
td4broncs
Colorado
I'll take them if they are available still! Getting ready to switch to turbo.. I'll send pm
Turbotungsten
Sorry I have been gone for a while so I am answering the 3 previous posts. I still have both sets (didn't hear from you today td4broncs). I ran lockouts and Manley Springs, but I don't know if it was necessary for either. They are only 501. max lift and not a lot of duration so you might get by with neither if you aren't running a lot of boost. For what it's worth, comp starts recommending springs at about .480 lift on 3v engines, so I would run springs.
