Exhaust Heat Wraps
Benwhite911
V6'ing & Dealing With It
Cape Coral, FL
Hopefully within the month I'll be installing Longtube Headers in my V6. I've been kicking around the idea of wrapping them up in heat wraps that can be found on American Muscle, and the likes. It appears that wrapping them up is far easier to do before installing, so just trying to figure everything out before I begin this. I see that some use them and some don't, so those of you that do; did you find that the exhaust heat wraps were a good choice, or was it something that you could have done without?
gavin.biegler
for what it's worth i didn't wrap mine (v8, not that it matters for this) and i wish i did.
ghunt81
New parts on old junk!
Clarksburg, WV
Also FWIW, I've heard that wraps are generally a bad idea.
Apparently because of the way they hold the heat in, they cause the metal to deteriorate...something about leaching carbon from the steel, I dunno. Not sure if this applies to stainless steel or not but I'd do some research before you commit to the idea.
gavin.biegler
i meant it doesn't matter mine is a v8 and yours is a v6, they're going to get hot regardless. why i wish i had is because my entire engine bay gets super hot, even the footwell inside the car does sometimes.
01yellerCobra
San Diego, CA
I heard it was more because the wraps hold moisture. Moisture+metal=rust.
Benwhite911
Cape Coral, FL
So the Carbon Steel that's used to make Pacesetters might not fair well with being wrapped it sounds like?
ghunt81
Clarksburg, WV
Not from what I've heard, no. I saw some accounts of guys pulling off wrapped headers and having them literally just fall apart.
tigerhonaker
TN
OP,
I see your speaking of your's being the six.
Once again what I'm going to say I don't think has anything to do with the engine being a six or eight.
I was going to have that done to mine to keep down heat in the engine compartment.
I was told NOT to have it done !!!
So, I listened and did not force the issue but I did not really inquire into why not have it done.
As I type this it seems to me that it was discussed with a Kooks Engineer and was told by that Engineer not to do it.
Terry
pass1over
I like it LOW
Trenton, FL
this is what i've heard as well.
that being said. I have a couple of primary tubes that are wrapped on my '66 b/c of a clutch cable routing, but i've never taken it off to see what it looks like underneath.
Benwhite911
Cape Coral, FL
OP,
Terry
Good info. Looks like something that isn't needed. Thanks guys.
Iceman62
Bullitt 6005
NE
Another option, for cooling your header(s), is ceramic coating...pretty cheap and much easier than wrapping. Might want to look into it...JMO.
94_cobra
Ceramic coating is probably a better alternative and maybe not much more $
travelers
Eastern Pa
I have mine on the '11 ARHs with ceramic coating from Swain Coatings which is a little pricey but good.
dustyn83
Just curious here if exhaust wrap can provide some performance gain or is it for looks only?
