New Product from UMI- 2011-2012 Ford Mustang Adjustable Rear Upper Control Arm
UMI Performance
Extreme Duty Rear Upper Control Arm for the 2011-2012 Ford Mustang
P/N 1066
Starting at $119.99/each
UMI Performance is pleased to announce the release of an adjustable rear upper control arm for the 2011-2012 Ford Mustang (P/N 1066). Upgrade from the flimsy, factory rubber bushing setup to improve responsiveness and reduce wheel hop upon launching. The robust, reinforced bracket is constructed from CNC machined 0.250” thick mild steel and reinforced with three-hole gussets for incredible strength. Premium rod ends allow for smooth articulation without the binding associated with the factory rubber bushings. The P/N 1066, with its on-car adjustability, allows you to easily set pinion angle for drag racing applications or correct pinion angle to compensate for vehicle lowering. The beautiful red or black powder coated P/N 1066 uses factory hardware and will allow you to harness the power of your new Mustang. Proudly designed and fabricated in Philipsburg, PA – USA.
Application:
2011-2012 Ford Mustang V6, GT, GT500
[FONT=&quot]Website Link Here- P/N 1066
[/FONT]
[FONT=&quot]
[/FONT]
