S197 Mustang Forum - S197Forum.com
Go Back   S197 Mustang Forum - S197Forum.com > Mustang s197 Tech Forums > Drift Racing Tech Discussion
Drift Racing Tech Discussion For the Drifters!
Reply
Thread Tools Display Modes
Old 06-30-2017, 12:15 PM   #21
OutlawEvans
OutlawEvans's Avatar
OutlawEvans is an unknown quantity at this point
Default
Build update! Got all of the previous mentioned parts in and have been running events left and right. Also placed 3rd in a top 16 competition in California!
Click the image to open in full size.
Also I got some Rotiforms for the stang for a steal too, they look nicceeeeee
__________________
Instagram: @Outlaw_Evans
Facebook: https://m.facebook.com/HaydenOutlawEvans/
OutlawEvans is offline   Reply With Quote
Old 07-12-2017, 11:42 AM   #22
46addict
13726548
46addict's Avatar
46addict is an unknown quantity at this point
Default
Car looks good! I see you got the SR coils for the car. They may cause issues later on as aftermarket coils are prone to fail on these engines.
How do you like the Feal coilovers? What spring rates did you go with?
__________________
Vista Blue Procharged 2007 GT Kurgan tuned
BBK Longtubes & O/R X--Magnapacks--FRPP hotrod cams--CMDP--3.73s--Exedy Mach 500--DSS Driveshaft
BC Racing Coilovers on 450F/335R--BMR UCA & LCA & relo brackets--MM panhard bar--Hurst Competition shifter
46addict is offline   Reply With Quote
Old 07-12-2017, 01:43 PM   #23
Brandon08GT
Brandon08GT is an unknown quantity at this point
Default
Such an awesome build! Curious on the coilovers as well. Would love to see some videos if you can put some in the thread.
__________________
2008 Mustang GT- Some Show, A Little Go
Brandon08GT is offline   Reply With Quote
Old 07-13-2017, 08:33 AM   #24
mavisky
mavisky's Avatar
mavisky is an unknown quantity at this point
Default
Need to know about that carbon fiber airbag cover on the passenger side. I have the APR units for the vents and the gauges, but they don't make that piece. Is that a piece that sticks to the factory piece or a replacement unit? Any idea where it may have come from?
BTW, sick build. Love a car that actually gets used.
__________________
2009 GT500 Vert - Vapor Silver - Stripe Delete - Red/Black interior (1 of 1) - VMP Gen 2 Powered
mavisky is offline   Reply With Quote
Old 07-19-2017, 08:47 AM   #25
zorph01
zorph01's Avatar
zorph01 is an unknown quantity at this point
Default
Do you have any issues locking up the rear end with a second stock caliper? I'm looking at doing the same but I'm wondering if I need to get a custom bracket for a dual piston Wilwood, or if a second stock caliper will be sufficient.
zorph01 is offline   Reply With Quote
Old 07-27-2017, 08:03 PM   #26
OutlawEvans
Default
Thanks for the tip! Unfortunately I didn't see that they failed until after I installed them haha. I went with 6k rear and 8k front! Justin pawlak recommended to go with those but I think 10k on the front would be best
__________________
Old 07-27-2017, 08:04 PM   #27
OutlawEvans
Default
Thank you!! Also I have no idea, everyones been asking me. the carbon fiber came with the car
__________________
Old 07-27-2017, 08:06 PM   #28
OutlawEvans
Default
Quote:
Not at all!! I had wilwoods on an s13 that could almost lock up in a straight line and the stockers cant really do that but once you turn in and pull the e brake they lock up instantly. I've used the stock calipers and e brake before also and it worked just fine
__________________
Old 07-28-2017, 04:22 PM   #29
mavisky
mavisky's Avatar
Default
Quote:
No worries. Just curious though if it's a replacement piece or if it is just like one of those stick on dash kits using double sided tape.
If it's a full replacement I would make you a sweet deal on it.
__________________
Old 07-28-2017, 05:43 PM   #30
OutlawEvans
Default
Car is FOR SALE as well! Decided I want to do road course racing instead in a spec e30 class with a friend. I cant post to the classifieds yet so here's a link
http://www.ebay.com/itm/253066679318...84.m1555.l2649
Edit: decided not too and keep building lol
__________________
Old 08-13-2017, 01:16 AM   #31
Anti
Anti is an unknown quantity at this point
Default
Good. I was getting attached.. lol
Anti is offline   Reply With Quote
Old 08-13-2017, 10:28 PM   #32
OutlawEvans
Default
So instead of selling the car to do road course racing I decided to aim the build for a top drift limited class I california! 3 rounds, 235 width tires max and 240 tread wear. Only thing to make the car legal is I have to put the door cards back in and trim them to fit. After that I plan on throwing in a unicorn angle kit, bigger radiator, oil cooler, and That's probably it. Hopefully I can podium with this thing in a series!
__________________
Old 08-14-2017, 09:14 AM   #33
mavisky
mavisky's Avatar
Default
Any chance you could answer this question?
Been trying to locate a carbon fiber trim piece for my passenger airbag cover and I'm down to stick on carbon or custom wrapping my own.
__________________
Old 08-14-2017, 11:42 AM   #34
Anti
Default
Did you not have to do anything with the UCA's and LCA's on that car?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Ad Management plugin by RedTyger
