07 S197 Coyote swap
lito
Caracas, Venezuela
New pulley for the supercharger.
Sent from my ASUS_Z00TD using Tapatalk
The01Cav
A coyote swap with a 6r80 has always been my dream plan to do in my 2009 v6 chassis.
Sonicblue_s197
I plan on doing a coyote swap this fall but is it possible to still reuse all the guages out of my 05? Tach, speedo, fuel, oil the works?
lito
Caracas, Venezuela
I haven't tested 05-06 but I don't see why it won't work being CAN, just connect them to the bus and voltage, temp, speedo and tachometer will work, fuel or oil has nothing to do with PCM.
Diablogt07
Wichita falls, TX
Hey lito I been thinking about doing a swap as well and I wanted to know what are your thoughts about doing one with a auto trans or if a stick I could use it to train myself Bc I learned I just need to touch up on it. Around how much was spent when you found good ppl to install? Like around what mark in price?
Hurley
Help me with the ect cant make it work
Rpm,mph and oil pressure already working
Juice
ECT as in temp guage? It should be working if your tach/speedo is working. Data logs show correct ECT?
