Gas pedal issue
Cole
My gas pedal has about an inch of give before it does anything. I can press the pedal down a whole inch before my engine starts to rev. Any way to fix this?
lito
Caracas, Venezuela
Mods? it is not always the pedal, a log would tell, if you can log APP (accelerator pedal position) and see it moving as soon as you depress it, leave it alone.
IF your TB is dirty or due to use or mods it needs a lot more air to idle and it reached the max correction, it won't use quite some part of the pedal travel.
Sinner
Plano, Tx
I had the same issue and it was the pedal... It just took about an inch before anything would happen. I just bought a new pedal and swapped it out. If I have the old one I'll send it to you so you can try to correct it like guys have done. I just didn't want to mess with it
05ELANOR
I have a gas pedal and break clucltch assembly. Pm me if need it
Cole
Solution:
I got a pedal from pick your part along with a bunch of other goodies! It works great now!
