Custom GT500 fuel system for 05-09 GT
For sale, take out 2010 GT500 dual fuel pump hat, hat had 15k miles on it when it was pulled from the car. I swapped out the level sender to a 05-09 level sender and modified the hat to be plug and play with the stock fuel hat connector and cleaned the pre filter, hat is in excellent condition. Includes my fuel system wire upgrade kit which uses a relay and 10awg wire to feed the fpdm directly from the battery to support the dual pumps. This setup will support around 650-700hp depending on setup and injector size and can also be used with a 40amp single bap to support more power, safe for e85 as well. The hat is a drop in replacement for yours and comes with instructions for an easy install on the wire kit. The unicorn dual GT500 fuel harness and second fpdm is not required for this kit!
$400 shipped in the cont. US.
_lop3z
Mesa az
Could you please text me at 480 371 7916 new to forums and new to 3vs as well have a few questions
