Paxton 2200 install
TxS197
08-09 GT Paxton 2200 guys
With the ford racing intake manifold
Did you have problems with the install
Specifically the thermostat housing hitting the manifold ?
The thermostat adapter plate puts the thermostat to high and keeps the intake from sitting down properly
Sent from my SAMSUNG-SM-G900A using Tapatalk
AndrewNagle
Mountains of NC
I believe Scott has accomplished this, I will look for a link to his thread
Scott
King City, Ontario, Canada
Sorry I would be lying if I said I took careful measurements as I just winged it! Recommend you take a careful look at the picture of the two cut pieces to estimate the angle. Once cut i rotated the cut piece 180 degrees for welding. I will also admit I cut the aluminium on a Dewalt chop saw with a 12 carbide tip blade. Still using the blade today without issue from everything from fine trim to 6x6 posts.
TxS197
Okay sounds good
Gonna tackle it tomorrow
Wish me luck
Thanks Scott
TxS197
Off topic question but what would gap the plugs at?
46addict
13726548
Lawrenceville, GA
Plug gap depends on boost level but I am running .030 on 9psi. I have seen recommendations range from .028 to .032.
TxS197
Okay cool mine are set at .030
Thanks
TxS197
Scott
I got the thermostat housing welded from a friend
But with the frpp tb I have as well it's a little tight running the radiator hose and the 90 between the tb and blower
How did you approach that part
Anything specific?
Scott
FRPP TB as well, it is tight but it does fit. Maybe the silicone radiator hose is a bit more flexible then the OEM hose, but I think when I first put the built motor in I was using the OEM hose.
WOW my hood has been open all winter and it is embarrassing to show you pictures of a very dusty engine.
Hope this helps, let me know if you need a different angel or something.
TxS197
Sorry just now getting back
Just about done with it still need to install Bap
Thanks Scott and everyone else for the info
