BruceH
BBB Big Bore Boss 322
Normally I have the machine shop check clearances. This time I'm building a motor that is using a factory new block so the only outside work needed was balancing the rotating assembly.
This leaves me with the task of checking bearing clearance. It was fairly easy with the rods but the mains use tty bolts so I can't completely torque them. This leaves the bearing crush and measurements in question.
First I torqued them to 30 ft lbs which is where they normally are prior to adding 90 degrees. At that point the clearance was right at a little under .003".
Keeping an eye on wrench deflection I continually added 5 ft lbs at a time and rechecked clearance. The last check was done with 65 ft lbs and came out between .0015 and .002 for all the mains.
At 65 ft lbs the wrench had deflected about 20 degrees and there was no sign of the bolts hitting the plastic state. I've torqued enough tty hardware to know when they are stretching as designed. IIRC the bolts are engineered to start the yield process at 66 ft lbs. I think the bolts were taken as far as they safely could be taken without entering the plastic state.
I'm wondering if any engine builders have done any type of sacrificial testing to determine how much if any the clearance changes with torque increases? I'm fairly certain it won't change much from here. Anywhere between .001 - .002" is fine and I know it's less than .002" right now. A guess would be that they are from .0019 - .0017 right now. The plastigauge calibration doesn't really show a more detailed scale than .0015 and .002".
So the question is will the clearance change much going from 65 ft lbs to 30 ft lbs + 90 degrees? If so how significant would it be?
I will still be able to check torque to turn after installation of the crank so if it needs more than max or is in the higher end I should know that something is up.
