Steeda's S550 Tri-Ax Race Short Throw Shifter is Here!
tj@steeda
Thought we just focused on suspension? Drivetrain is our forte as well!
Steeda's S550 MT-82 Tri-Ax Race Short Throw Shifter is a full factory shifter assembly replacement for your 2015-2016 Mustang GT or EcoBoost. Our race short throw shifter eliminates all slop and deflection of the factory shifter, and still retains the factory shift knob, pull-up style reverse lockout and backup camera functionality.
Product Benefits
- 30% throw reduction
- 20% lighter than the competition
- Eliminates slop and shifter deflection
- Shift knob sits 1" lower for ideal 'power shifting' position
- Top-loaded installation with adjustable springs, in-car assembly
- Retains factory pull-up reverse lockout, OE thread pitch, and back-up camera functionality
- Includes Steeda's shifter base bushing bracket
- Precision-fit bushings for a direct positive feeling shift
- Steeda blue anodized finish
- Lifetime Steeda warranty
- Made in the USA
Steeda S550 Tri-Ax Race Short Throw Shifter - GT | 555-3717
Steeda S550 Tri-Ax Race Short Throw Shifter - EcoBoost | 555-3718
With the replacement of your factory shifter assembly with our short throw shifter, you will notice a 30% reduction in throw between gears. Our shifter assembly will also lower the shift knob by 1", putting it in a better 'power' shifting position. Our Steeda S550 Mustang Tri-Ax Race Short Throw Shifter is quieter than the stock shifter during daily driving, although during race applications you may notice a slight NVH increase.
80-steeda_s550_mustang_gt_mt_82_tri_ax_race_short_throw_shifter_15_16_gt_555_3717_01_zpsofoqs3bp_d3ea7a470440a660dcc760287de9100886084312.jpg
80-steeda_s550_mustang_gt_mt_82_tri_ax_race_short_throw_shifter_15_16_gt_555_3717_00_zps8mtopako_43e94e0240a72a8e6aa9fc03c4a137d35ca01ecf.jpg
80-steeda_s550_mustang_gt_mt_82_tri_ax_race_short_throw_shifter_15_16_gt_555_3717_02_zpsr3x4vskx_7926e2b414a0d5847c0bae82c3ee78b76cb31f03.jpg
80-steeda_s550_mustang_gt_mt_82_tri_ax_race_short_throw_shifter_15_16_gt_555_3717_03_zpsfwmkqbw7_b57e6d9619c139f87886958b93a21a8f9b86dab9.jpg
One of the great benefits to this shifter assembly is that it's completely top-loaded. Our short throw shifter for your 2015-2016 Mustang GT or EcoBoost comes with 2 different spring set options for a fully adjustable shifting experience. The kit comes complete with 2 medium-resistance springs and 2 high-resistance springs. The Steeda Tri-Ax has adjustable return springs to fit every drivers' preference on shifter feel. Using an offset spring tension ensures that you hit your 2nd-3rd gear change every time. Since our S550 MT-82 short shifter is top-loaded, once the base plate is mounted, you can change all of your springs, levers and other options all from inside the car without taking out the full shifter assembly!
80-steeda_s550_mustang_gt_mt_82_tri_ax_race_short_throw_shifter_15_16_gt_555_3717_04_zpsmwusoxbo_8cc3ad96af608827f0b5c9d52d0db3f2a98ada89.jpg
80-steeda_s550_mustang_gt_mt_82_tri_ax_race_short_throw_shifter_15_16_gt_555_3717_05_zpse6ezyx5g_ffde8cda3c0220b08a986f22a84c56e8719d878e.jpg
Our Tri-Ax shifter features rigid mounting in the front and Steeda poly bushing in the rear, virtually eliminating slop and shifter deflection. With less deflection you will feel a much more direct gear change. The assembly is transmission and chassis-mounted so you don't get the 'walking' affect of a fully transmission-mounted assembly, all while still gaining a more rigid shifter feel. Factory shift shaft bushings are replaced with wider, high-quality machine-finished, low-friction bushings. Tolerances are controlled up to a half thousandth of an inch to ensure OE-quality fitment, alignment and shaft actuation. These features alone make our Steeda Tri-Ax one of the most positive feeling shifters on the market today. To top it all off, our Steeda Mustang GT shifter assembly includes Dynamat sound-deadening material to close out your transmission tunnel and ensures your S550 stays as quiet as the stock assembly.
80-steeda_s550_mustang_gt_mt_82_tri_ax_race_short_throw_shifter_15_16_gt_555_3717_07_zpsmhh1linr_0b044d7bcffdc2e2e7f3c6ad635614a70283cefd.jpg
Steeda's S550 Mustang MT-82 Tri-Ax Race Short Throw Shifter is manufactured from high-quality aircraft-grade aluminum making it 20% lighter than the competitions' shifter assemblies. The shift lever itself on our Tri-Ax is made from heat-treated and nickel-plated 4140 steel, making it the strongest part out on the market. All hardware is stainless steel for the highest corrosion-resistance possible. Included in our kit is hardware to tighten up the factory shift knob perfectly into a locking position. These parts have been put to the test on the street and the track and are proven not to bind under extreme conditions or temperatures.
Priced competitively at $439.95 and backed by a lifetime warranty, pick-up one of our Tri-Ax shifters today and shift with confidence!
80-steeda_s550_mustang_gt_mt_82_tri_ax_race_short_throw_shifter_15_16_gt_555_3717_09_zpsyzj2wcm9_aa5b46520acf50429c7f88f2f93b2b23e33f236c.jpg
Best Regards,
TJ
