06JET
I didn't think about the drone. I removed the Flowmasters and went with the Roush, because of drone. I can't stand it. Thanks for the info.
You actually don't "lose" the torque. It just moves in the power band to a higher RPM. And the hollow cats echo and drone and sound terrible.
So why is it that the factory blown cars (Roush-Shelby) cats hold up? What is the difference?
OK then, let me ask this---If I have to take the cats off and go with a cat-less pipe will I have to change the tune???? If the cat material starts to break up or fail can I just beat/remove it out and still use the pipe?
I thought pulling timing will raise EGTs which takes a toll on cats? And a richer mixture means more unburnt fuel through the system which makes matters worse.Relatively low boost/power levels with a generic conservative calibration using all the factory sensors, limiting rpm, retains rear 02 function for cat cooling, richer fuel stoich, conservative spark, pulls timing based on iat, etc. Which helps keep them cool and lower egt etc. That kind of stuff would have to make a difference on cat life.
I was told that rich cools the cats and lean is hotter = more power (until you melt it down).
So if my rear O2's are working and my tuner said that he was a little fat on the top end then my cats should have a fighting chance......right?
And yes hollowed out cats will sound much worse. Sounds raspy as hell.
And yes hollowed out cats will sound much worse. Sounds raspy as hell. Go off road midpipe with the magnapacks or borla stingers which is what I have. If it's too loud, you can add a 12 inch dynomax bullet resonator to each side and you will have no rasp. I've tried almost every exhaust combo out there. I should have my car running in a few weeks, I can meet up or send sound clips if your in the Boston area
I would go with the Kooks catless pipes to replace the catted ones you have now. You should be able to get just the 2 short pieces from the headers to the mid pipe and still use the "H" you already have. Then i would look into some mid mufflers like glass packs to go in the two over the axle pipes just before the axle. If not it will be louder with out the cats.
