4r70w Gap
1bad99
Texas
need help with what is the recommended converter to fly wheel gap. doing 4r70w swap in my 07. i used the search but was no luck finding what i needed
TexasBlownV8
Formerly TexasBlownV6
Central Texas
thought it was 1/8". But that's not an official spec. (I think mine's 1/8")
[wtf are you doing with a 4r70???!!! Gimme a call if you need to.]
05stroker
Never enough power guy!
Bullard Tx.
When I was searching this for my 6r swap I found 1/8" to a max of 3/16" to be a standard.
RocketcarX
95% of my weight is fuel
Colorado
I'm curious why this seems to come up so much with the 4R70W swap...does it not just bolt up like factory?
swflastang05
Back for More
N. Ft. Myers, FL
This is also what's listed in the paperwork that came with my FB 4r70w. I usually set mine around .135, sometimes you need to install some washers to get it right.
1bad99
Texas
I ended up getting a spacer kit from circle D for free they send it added the washers and was good
