05gtkb
Putting up my 05 gt forsale. it is highly modified. Thinking of getting into something different is the reason for selling. nothing wrong with the car at all. Asking price is 17kobo.
2005 Mustang GT Premium UA Black
2 Owners (have original window sticker)
96,000 miles
Interior
Red leather seats w/ red leather door inserts and red floor mats (factory option)
Shaker 1000 audio system w/ x2 10in subs and amps
Raxiom navigation/audi system w/ backup camera (just installed)
Kenne Bell Boost and Fuel pressure gauge with dual gauge pillar pod
SHR Shift knob with boot retainer (just installed)
Exterior
Oem gt500 hood
MMD Hood struts
Shorty antenna
Black Modern retro billet grill upper/lower
Cdc decklid panel
Black GT fender Badges (just installed)
2 complete sets of lights 1 set is tinted the other is oem (head lights, tail lights, side markers, turn signals, and third brake light)
MMB Quarter window louvers UA Black (just installed)
MMD Ducktail Spoiler from AM BNIB painted UA Black (just installed)
Engine
Ford racing gt500 strut tower brace
Kenne Bell 2.6L Sc kit
39lbs injectors
Boost-a-pump
Kenne bell intake
Stock throttle body
Other than kenne bell kit engine is untouched and runs strong
Exhaust
Pypes long tube headers
Pypes off-road xpipe
Roush extreme axle back
Drivetrain
Stage 3 Tr3650 Transmission (carbon fiber synchros/assemblies, bronze fork pads, and 26spline input shaft built by Texas motorsport in san Antonio)
Built rear end- strange 31 spline axles, welded axle tubes and hardened/extended wheel studs 355gears
Custom made rear end brace
Trick flow diff cover
Spec stage 2 clutch
Spec billet steel flywheel
New slave cylinder
Mcleod stainless steel braided clutch line w/ bleeder
H-tek aluminum 1pce driveshaft (Will be switched out with a Drive shaft shop 1 pce aluminum ds
Barton shifter
Suspension
Steeda pro action shocks and struts
H&R super sport springs
Steeda panhard bar and panhard brace
Steeda adj UCA
BMR LCA
BMR LCA relocation brackets
Wheels
AM 2010 Gt500 Reps Black
19x8.5 275/40 front
19x10 305/30 rear
SCT X4 tuner
Tuned by Mike Murillo @ murillo motorsports
3 tunes DD tune, Race tune, emissions tune
All fluids have been changed
Gauge cluster was replaced by Ford because the stepper motors went out.
Majority of the drivetrain has maybe 1500 miles on it. The miles will not really go up too much bc I am currently deployed. I will include extra sc oil, engine oil and anything else that I have for the car.
Not installed (will include if price is met or close to): new shortblock, Mahle pistons .20, eagle h beam rods, cast crank, meiling oil pump
MHS stage 3 cams, locked phasers, vcts, bbr valve springs and retainers, new cams bolts and new cam sensors
twin gt500 fuel pump return style stup, w/ harness precut for bap, and extra fpdm
Brand new Bosch 1000cc injectors
96,000 miles
Interior
Exterior
Oem gt500 hood
MMD Hood struts
Shorty antenna
Cdc decklid panel
Engine
39lbs injectors
Boost-a-pump
Kenne bell intake
Stock throttle body
Exhaust
Drivetrain
Spec stage 2 clutch
New slave cylinder
Barton shifter
Suspension
Steeda adj UCA
BMR LCA
Wheels
19x8.5 275/40 front
19x10 305/30 rear
SCT X4 tuner
