2012 mustang race car
Blazer707@TBR
Official Vendor
Nor Cal
Trailer not for sale, only car.
2012 Mustang GT
Kona Blue
Originally a brembo, M6 premium car
Original owner is myself
ENGINE:
MMR 5.2 1500 series short block
Sleeved
Billet rods
Manley MMR pistons
No oil squirters
MMR oil pump gears
MMR crank sprocket
MMR billet chain guides
MMR secondary tensioner flip kit
MMR cooling head mod
MMR VCT phaser deletes
Stage 3 comp blower cams locked out
MMR valve springs
MMR ported and polished heads
MMR HD secondary timing chains
Arp head studs
Arp main studs
Arp main side bolts
ATI 10 rib 20% OD balancer
JPC water pump pulley
MMR vct valve cover block off's
Boss intake manifold
Engine has around 40 miles on it with 10 dyno pulls.
POWER ADDER:
Vortech JT-B
8 rib
Tail bov
3.47 pulley
3.15 pulley
EXHAUST:
Stainless power 1 7/8 long tubes
Catless x pipe
Stainless works race catback
FUEL SYSTEM:
Fore triple pump setup
Fuel system ran in parallel
Triple TI 267's
ID 1300s
TRANSMISSION:
6r80
Exedy stage 2 clutches
Exedy billet shaft
New valve body
Circle D 4c 5 disc lockup
Dyno tech aluminum driveshaft
WHEELS AND TIRES:
15x10 weld v series rears
M/T Pro's 275/60R15
15x3.5 weld v series fronts
M/T bias ply 26inch skinnies
BRAKES:
Stainless steel braided lines
Line lock
Watson racing CJ brake lines
Manual brake master cylinder
FRPP proportioning valve
Strange billet hub drag brakes front
Strange drag brakes rear
REAR END:
Stock 8.8 houseing
Strange 31 spline c clip eliminator axles
Tru Trac differential
3.31's
UPR differential cover
Strange 5/8 rear wheels studs
Tubes welded
SUSPENSION:
Rear Viking crusader shocks
Rear BMR drag springs
Steeda spherical uca houseing bushing
BMR spherical adjustable lower control arms
BMR spherical UCA and mount
BMR anti roll bar
Front Viking coil overs
Maximum motorsports camber caster plates
BMR front kmember
BMR tubular a arms
BPS radiator supports
STEERING:
Flaming river manual rack
Custom 1 piece steering column
Strange quick release steering wheel hub
Grant steering wheel
SAFETY:
Dow brothers custom 8.50 NHRA cert cage
Window net
Racequip 5 point seat harness's
Kirkey drag seats with covers
Dj safety engine diaper
Tig vision chute mount
Stroud chute
Ebrake handle is chute lever
Stifflers driveshaft loop
Battery located in trunk with battery cutoff
MISC:
Hardwood 3 inch lift off CF cowl hood
MMR carbon fiber dash
Lund ngauge
Saleen grille
Optic Armor windows front and rear
Trans Break wired up
UPR vacuum block
MSD 2 step
JPC coolant tank
Car has no a/c or heat
The paint is not in perfect shape, could really use a good detail and get the swirl mafks out of it, has small scratches on drivers door and the CF hood has some spider cracks under the gel coat that I planned on just having the hood wrapped gloss black.
Car weighs 3085 without driver.
Car made 780/550 on a dyno jet with 12 psi of boost.
I am sure I am missing something but feel free to ask.
Asking 30k car only
Feel free to call or text for any more info or pictures. 7076855219
Located in Dixon, California
-Thomas
https://www.flickr.com/photos/69554327@N04/
spaded707
IMG_1060https://www.flickr.com/photos/69554327@N04/
