Clutch and Flywheel
Ereiniontas
Hello all, I am currently replacing the Clutch, Flywheel and Hydraulic Throwout Bearing on my 2012 V6, I bought a RAM clutch and an Exedy Flywheel, will those work together? Or will I have to look at getting an exedy clutch as well?
Ereiniontas
No but I am wanting to upgrade the car slowly so I got a better clutch and flywheel.
Nightmare37
The stock dual mass flywheel is notoriously famous for failure and a cause for deceleration vibrations ~2800ish RPM's. mine failed and I'm not heavily modded. I went with the ram twin disc clutch kit with a ram adjustable hydraulic throw out/slave cylinder.
Every aftermarket flywheel will have a different thickness than stock, the slave cylinder needs to be measured and spaced properly.
Bonus note on the twin disc clutch kit.... they are balanced as a matched set.
