S197 Mustang Forum - S197Forum.com
Go Back   S197 Mustang Forum - S197Forum.com > Mustang s197 Tech Forums > Drift Racing Tech Discussion
Drift Racing Tech Discussion For the Drifters!
Reply
Thread Tools Display Modes
Old 08-23-2017, 11:48 AM   #41
OutlawEvans
OutlawEvans's Avatar
OutlawEvans is an unknown quantity at this point
Default
Going to be compression checking the 4.6. If it doesn't do too well I'm thinking of doing a coyote swap, if all seems good then I'm thinking of a roush super charger
__________________
Website: http://www.fortheloveofdrift.com/
Instagram: @Outlaw_Evans
Facebook: https://m.facebook.com/HaydenOutlawEvans/
OutlawEvans is offline   Reply With Quote
Old 08-23-2017, 07:01 PM   #42
Anti
Anti is an unknown quantity at this point
Default
Quote:
I dunno how well the whole pulleys thing will do with drifting. Honestly would think turbo would be better.
Anti is offline   Reply With Quote
Old 08-25-2017, 01:37 AM   #43
OutlawEvans
Default
Quote:
What's the downside of it? I don't have much experience with super chargers, the market for them seems pretty good for mustangs though
__________________
Old 08-26-2017, 12:02 AM   #44
Anti
Default
I've watched videos of people having issues with keeping the belt from popping off at high rpm. However on this forum i have seen some roots style superchargers that have two idler pullies on either side of the supercharger pully. Maybe those are ok.
Old 08-28-2017, 04:15 PM   #45
OutlawEvans
Default
Ahh I can see it now. I'll have to do some research around that more.
I've officially decided what route to go with the car! Going to be doing the 3 rounds of top drift limited next year and also 6 rounds of Redline time attack! I'm interested in setting up a car that could do both, of course it'll be a challenge but I think it'll be fun for sure. Here's also some in car at the grange a few months ago, I think I need to work on staying on the throttle more and not modulating so much.
https://youtu.be/xamOrqg-YzY
__________________
Old 09-06-2017, 09:00 PM   #46
OutlawEvans
Default
Hey Guys! If you do like my build and want so see more I built a website, It also has some tips about drifting as well as regular blog posts too. If anyone checks it out I appreciate it a lot!
__________________
Old 09-12-2017, 02:10 PM   #47
46addict
13726548
46addict's Avatar
46addict is an unknown quantity at this point
Default
Quick update of parts I'll be throwing on and what else I plan on doing. Any input is appreciated
-Bmr relocation bracket for rear arms
-bmr upper arm
-grantelli Motorsports front and rear sway bars
Still planning to buy
-caster/ camber plates
-unicorn angle kit
That's really everything I could think of to still do other than boosting it
The coilovers you bought come with camber plates so there's no need for separate plates.
As for the relocation bracket, they are designed to increase grip at corner exit/drag launch which could have adverse effects on a drift car. For the upper control arm, get one that has spherical/rod end bushings. The polyurethane ones will bind up under load and can make a car unpredictable at the limit.
In any case, change/add one thing at a time so you know what to undo if you end up with an ill handling car.
__________________
Vista Blue Procharged 2007 GT Kurgan tuned
BBK Longtubes & O/R X--Magnapacks--FRPP hotrod cams--CMDP--3.73s--Exedy Mach 500--DSS Driveshaft
BC Racing Coilovers on 450F/335R--BMR UCA & LCA & relo brackets--MM panhard bar--Hurst Competition shifter
46addict is offline   Reply With Quote
Old 09-13-2017, 10:00 AM   #48
OutlawEvans
Default
There's no camber/caster plates I must have missed putting that. I got camber adjustment but need caster adjustment so I'll be getting maximum Motorsports plates.
Also I'll probably be getting a Unicorn Angle kit as well in the next few months and probably up the gearing into the 5 range
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Ad Management plugin by RedTyger
