Custom Built 427 Stroker Motor
nawtbird
Just throwing this up here for anyone that maybe looking for a Engine for a kit car, street/hot rod, etc
Custom built in house 427 - 351W Stroker Motor.
Made 560 HP 560 TQ on 93 Octane Pump Gas.
Watch the dyno run
http://goo.gl/SBSmx9
nawtbird
Ooops -- $14995
Built with all new top shelf parts
Only time is on dyno -- proper break in procedure on dyno
Build Sheet:
  • World Products Man O' War 351W Block with Billet Splayed 4 bolt Main Caps
  • Edelbrock Custom Built Victor JR 351W Heads with 70cc Chamber --
    • Edelbrock 2.055/1.60 Stainless Valves
    • Isky Dual 1.530" Valve Springs
    • Isky Valve Spring Locators
    • Comp Cams 10* Retainers
    • Comp Cams 10*Valve Locks
    • ARP 7/16" Rocker Arm Studs
    • Edelbrock Guide Plates
    • Scorpion Aluminum 1.6 Ratio 7/16" Stud Mount Roller Rocker Arms
  • Edelbrock Victor Jr Single Plane Manifold
  • SCAT 4340 Forged 4" Stroke Crank with 2.750" 351C Mains
  • SCAT 4340 Forged 6.250" H-Beam Rods with ARP 2000 Bolt Upgrade
  • MAHLE Performance Forged -26cc Dish Piston with Plasma Moly Rings
  • Clevite 77 H-Series Race Main Bearings
  • ACL Performance H-Series Race Rod Bearings
  • Durabond Performance Cam Bearings & HP Hardware Kit
  • Ford Racing 9 Keyway Timing Set & 1 piece fuel pump eccentric
  • Competition Cams Custom Ground Hydraulic Roller Cam with 351W firing order
  • Melling Performance Retro-fit Hydraulic Roller Lifters
  • Pioneer Timing Chain Cover
  • Powerbond Performance Harmonic Balancer - Internal Balance
  • Milodon Aluminum High-Flow Water Pump
  • ARP Headstuds
  • ARP Balancer Bolt
  • ARP Oil Pump Shaft
  • ARP Engine Bolt Kit
  • All Fel-Pro Performance Gaskets
  • Manley 5/16" .080 Wall 1 Piece Pushrods
  • Moroso 7 Quart Front Sump Oil Pan - Baffled with Windage Tray
  • Melling Performance M-Select Standard Volume Oil Pump
  • Ford Racing Polished Valve Covers with Custom 427 Logo and Blue Striping
  • MSD Ready to Run Distributor
  • Roush Performance 9mm Spark Plug Wires
  • NGK Spark Plugs
