- Joined
- Jan 7, 2013
- Posts
- 306
- Reaction score
- 0
2011-2012-2013 TVS Roushcharged Mustang 650 HP Power Package Upgrade
If you have a 2011, 2012 or 2013 TVS Roushcharged Mustang and are looking for MORE POWER then look no further!! JDM Engineering has put together a Roush Mustang Power Package that will add 100 HORSEPOWER and over 120 foot pounds of TORQUE to your 2011, 2012 or 2013 Roush Mustang! This kit is tested and developed in house on Team JDM's Roush Stage 3 Mustang equipped with the TVS Roushcharger. Hundreds of dyno pulls and quarter mile runs along with thousands of hours in JDM Custom Tuning Development have brought us to this incredible power increase for your 2011, 2012 or 2013 Roushcharged Mustang!!
JDM Engineering's Jim D'Amore will build a custom tune file for your 2011, 2012 or 2013 Roushcharged Mustang and load it on to a SCT Xcalibrator 3 programmer specifically for your vehicle. An 82mm Supercharger Pulley and shorter belt are included to raise boost levels on your Roushcharger up 3 psi over stock! This is where a good bit of power and torque are gained! Colder spark plugs are included to help fight off detonation and spark blow out from the extra boost pressure and heat generated by the smaller pulley. Finally, a Roush Cold Air Intake kit #421529 is included to increase in air flow to the Roushcharger. This complete 2011-2012-2013 Roushcharged Mustang 650 HP Power Package will yield nearly 575 RWHP with out any other modifications!
With the addition of a Larger Throttle Body and Higher Flowing Exhaust, horsepower levels as high as 600 RWHP have been seen in testing! For more information about other parts to add more power, check out our 2011-to-2013 Mustang sections or give Team JDM a call at 732-780-0770.
Run Like the Pros with Team JDM!!
The 2011-2012-2013 Roushcharger Mustang 650 HP Upgrade Kit Power Package Includes:
-SCT X3 Programmer with JDM custom Tune File
-Roush Cold Air Intake Kit -421529
-JDM Engineering 82mm Supercharger Pulley
-Gates Belt K060810
-Ford Racing 0 Degree Spark Plugs M-12405-M50
2011-2013 JDM Engineering Roush TVS Mustang 650 HP upgrade kit (Stock/Modified Comparison)
-Stock Roush Kit = 540HP (475RWHP)
-Stock Boost Level is 7-8PSI
-Modified Using JDM Engineering Roush TVS Package 650HP/600TQ = 575RWHP/525TQ 100HP+ Gain!!
-Modified Kit Produces 11-12PSI of Boost with 82mm Pulley!!
The 2011-2012-2013 Roushcharged Mustang 650 HP Upgrade Kit Power Package fits:
-2011 Roushcharged Mustang
-2012 Roushcharged Mustang
-Gates Belt K060810
