S197 Mustang Forum - S197Forum.com
Go Back   S197 Mustang Forum - S197Forum.com > Mustang s197 Tech Forums > 2007+ Mustang GT500 Tech
2007+ Mustang GT500 Tech Technical discussion about the 2007+ Ford Mustang GT500
Reply
Thread Tools Display Modes
Old 06-14-2016, 03:40 PM   #1
Devcon 7
Devcon 7's Avatar
Devcon 7 is an unknown quantity at this point
Default Anyone done a 4l80e swap?
Have a 10 gt500, and thinking I want to go fast. I can get a built 4l80 fairly reasonable from a friend but wondering what all it takes? Read that it fits with "light massaging" but would like to talk to someone thats done the swap.
__________________
2010 Shelby gt500
Devcon 7 is offline   Reply With Quote
Old 06-17-2016, 05:37 PM   #2
Speedboosted
Found missing cylinders
Speedboosted's Avatar
Speedboosted is an unknown quantity at this point
Default
My friend Steve Erickson has in his '07. He added a manual valve body and didn't even need a retune. Just went 8.8 a couple weekends ago after minimal testing. Are you a member on SVTP?
__________________
Comp Cams - Bilstein - Forgestar - H&R - Whiteline - Ford Racing
Speedboosted is offline   Reply With Quote
Old 06-19-2016, 06:13 PM   #3
Devcon 7
Devcon 7's Avatar
Default
Yes sir, am a member on svtp. Do you know what he gave for the bell housing? Ill also be running a fmvb, also looking at 4r70. Does he like his?
__________________
2010 Shelby gt500
Old 06-20-2016, 01:50 AM   #4
Speedboosted
Default
Quote:
Loves it. They did have to beat the trans tunnel a bit to make room to fit it all, but I don't know what all he did money wise. Serickson1 is his username over there if you want to send him a PM about it.
__________________
Old 06-20-2016, 08:16 AM   #5
retfr8flyr
The Old One
retfr8flyr's Avatar
retfr8flyr is a name known to allretfr8flyr is a name known to allretfr8flyr is a name known to allretfr8flyr is a name known to allretfr8flyr is a name known to allretfr8flyr is a name known to all
Default
You may want to contact JPC, they have done several swaps and may be able to help you with some information.
__________________
Earl
IF YOU DON'T STAND BEHIND OUR TROOPS FEEL
FREE TO STAND IN FRONT OF THEM.
Auto, TurboHorspower TT, FordGT fuel pumps, Circle D T/C, Driveshaft Shop Drive Shaft, 3.27 gears with Detroit True-Trac, Moser Axles, Wilwood Frt & Rear Brakes and more. Tuned by Mick Rousch at MAP [email protected] at MIR
retfr8flyr is online now   Reply With Quote
Old 06-25-2016, 01:29 PM   #6
Devcon 7
Devcon 7's Avatar
Default
Building a 4r70w is going to be the most cost effective route for 700 and under hp. Thank you for all the information guys!
__________________
2010 Shelby gt500
Old 06-25-2016, 11:23 PM   #7
roberts
roberts's Avatar
roberts is an unknown quantity at this point
Default
Can always do a th400 i have half of the cost of the 4r i was going to build. Plus the th400 holds alot more power compared to the 4r i was going to build!
__________________
2005 Mustang GT (Built not Bought)
built motor (STOCK CRANK) Turbo car
Th400 swap trans
CAR MADE: 780 hp 649 tq on 16 ps
roberts is offline   Reply With Quote
Old 06-27-2016, 05:32 PM   #8
Devcon 7
Devcon 7's Avatar
Default
Quote:
That was also another option but I really want overdrive unfortunately
__________________
2010 Shelby gt500
Old 06-27-2016, 05:48 PM   #9
roberts
roberts's Avatar
Default
4R but expect a lot of money to build it for good power!
__________________
Th400 swap trans
Old 08-15-2016, 11:22 AM   #10
13726548
13726548 is an unknown quantity at this point
Default
How about a 700r4?
__________________
13726548 is offline   Reply With Quote
Old 08-15-2016, 05:22 PM   #11
NUTCASE
NUTCASE is an unknown quantity at this point
Default
Quote:
Originally Posted by 13726548 View Post
How about a 700r4?
I have broken 700r4s on stock 305s. In my 3rd gen F-body days I replaced 4 or them. One of them was built behind a stock block carbed and sprayed 350. Another was behind a 400 truck motor with smog heads and cam. Still couldn't hold.
you can set them up for off road and mediocre towing.
But for just about anybody on this page look elsewhere.
__________________
Sig-less for weight reduction
NUTCASE is offline   Reply With Quote
Old 08-15-2016, 05:37 PM   #12
RazorbackMustang
MT82 Lover
RazorbackMustang's Avatar
RazorbackMustang is an unknown quantity at this point
Default
What about a 4R100 instead?
__________________
Lucas
2011 Mustang GT
2013 Fusion Titanium
RazorbackMustang is offline   Reply With Quote
Old 08-16-2016, 10:49 AM   #13
NUTCASE
Default
I have been waiting to hear about people doing a 4R100. Unfortunately I don't have the time or money to go pioneering with that.
__________________
Old 11-18-2016, 04:31 PM   #14
SNAKE08
SNAKE08's Avatar
SNAKE08 is an unknown quantity at this point
Default
Quote:
4r100 here and love it !
BTS in Lead Hill AR can give you the info you need. He has the whole kit available..
__________________
Another 9 second street car
SNAKE08 is offline   Reply With Quote
Old 04-11-2017, 08:51 AM   #15
skaarlaj
Probie Former Pink Bus Rider
skaarlaj is an unknown quantity at this point
Default
I had an 03 Lightning with ported stock blower, pullied to the max with 150 shot on top of that, and I can say that that 4R100 trans with a cheap stall converter, and aftermarket valve body was a very tough trans to say the least. I must have launched that 4700+# truck 200 times on slicks and performed flawlessly every time down the track
__________________
Kona Blue 2011 premium GT with 32,000 miles!
Paxton, 8 ribbed, wastegated, ATI 20% od balancer
6R80, 5C converter, Mid Atlantic tuned
Pypes long-tubes, and off road X into MBRP axle-back mufflers.
skaarlaj is offline   Reply With Quote
Old 04-19-2017, 12:36 AM   #16
Tuco63
Tuco63 is an unknown quantity at this point
Default
I used to run a FB 4R70W - excellent transmission. I didn't want to give up OD, either. Fast streetcar, not a race car
__________________
2014 Mustang GT, 6R80
Tuco63 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Ad Management plugin by RedTyger
