Raptor shift light off of PCM feed
Fordbanger
Grand Bay Al.
Good info I know the pcm method works with anything requiring a cto. Don't know if that is the same with the coil wire hook up.
91svtcoupe
Anyone know for sure if a msd window switch will work connecting to the pcm connector on an 05?
I know the 07-up has a tach out put but haven't seen anything on the 05-06 for sure
Also has anyone thought or do u know if there is a wire going to the obd plug that has a tach signal?
I wander about this because my aeroforce gauge reads rpm spot on....maybe there is something in the gauge but it has to read some signal from that port and I would assume the wires going to that port transfer those signals. ...my aeroforce works great for a digital tach when I want to read it that way and ive set my shift light up in it ans it has been working without any issues
lito
Caracas, Venezuela
Is not, the CTO is an actual 8 cyl signal (4/rev) with the coil wire, it is 1 cyl (0.5/rev) frequency is very low, for a shift light, no biggie, it only needs to read higher freq/revs but for other things, not good, if you get to monitor that, at idle is all over the place.
No CTO on pre-07, the aeroforce uses actual PCM's CAN data.
91svtcoupe
So no real good source for a tach signal unless u get a tach adapter then or purchase the digital window switch and correct the setting after tapping into the cop wire
On my 06 back when I purchased it new...I used a wire in the passenger side floor board kick panel aera but I cant find any info on that now....it seemed to work fine? Can u provide any information on what I may have tapped into there?
Fordbanger
Grand Bay Al.
At idle speed mine holds at the desired rpm. Also have used it for a window activation switch. Which didn't activate until 2000 Rpm's. So maybe that's reason it seems reliable for my source use. Good info though i will defiantly keep this in mind.
