CMDP DIY
06Torch
Houston, TX
LOL!
You got balls my man!
That shit would not fly at my house! :roflmao:
Gerardo
Preston951
Foglight delete kit!
Hey guys, I made a set of these myself using this thread. Awesome!
However... everyone at AFM is telling me that "epoxy-steel" people use to fill the hole is very unsafe. They say it'll flake off, deteriorate, etc from vibration and gas vapors. Any truth to this? If one of those little plugs ever came out the engine would be toast.
I don't want to install the DIYers before I gain some confidence. :)
Greg Hazlett
Stepping on the Pink Bus
Chesapeake, VA
Are there any before/after numbers on these? Do these gain you more hp? Tq?
06Torch
Houston, TX
This is my concern too. I have a set waiting for me in the garage. I can see this happening if the area to be filled was not prepared correctly. As in oily, dirty, etc... or was applied with little dry time. I'd hate to have to be the guinea pig for this one.
Steven,
Have you had a chance to do yours?
Gerardo
bolivianpimp
Spring ,TX
I have a set of stockers in my garage also that i want to try out with. The instructions are pretty good (thanks kleistang!) , but i have the same concern as others on the liquid steel coming loose into the engine.
Styre
It Happens
Lancaster S.C.
i used liquid steel on a cracked oil pan one time and it never broke/cracked again. I think the oil pan gets hotter then a intake. It looked the same a year after i done it as it did the 1st day. I guess you could use it on scrap metal and beat it with a hammer or something?
Mustang30212
Columbus, Ga.
What is was Ford's reasoning for these plates in the first place and what is to be gained by deleting them? I've done some reading on here and I know there is HP to be gained by doing this mod...but what are the effects to driveability?
RH
Rasmus
http://www.faqs.org/patents/app/20080314352
It is known in the internal combustion engine arts to provide variable valve mechanisms in the runners of the intake air manifold to provide charge motion control. The "charge" refers to the air or air-fuel mixture entering the combustion chamber, and the "motion" refers to the swirling, tumbling motion of that mixture. A charge-control valve serves to disrupt the laminarity of air or air/fuel mixture moving along the intake manifold runner and imparts a specific turbulent motion to the mixture entering the cylinder head. This motion is desirable to promote complete atomization of the fuel in the air stream and to insure even distribution of the air and fuel. A well atomized, homogeneous mixture of air and fuel results in better burn characteristics in the cylinder and allows for more efficient engine operation. Most cylinder heads are designed for good mixture motion at high flow conditions, so a charge motion control valve is needed only for lower rpm or idle conditions to promote charge motion by guiding the flow. During higher flow conditions the valve elements are removed from the flow path to avoid flow restriction. Such restriction can be undesirable at very high air flows wherein high turbulence is already inherent in the flow, and flow restriction should be minimized.
...and...
Butterfly-type pivoting valves are well known. The valve element itself is mounted on a pivotable shaft mounted transversely of the air flow path through the runner. In some older prior art embodiments, the shaft is mounted approximately centrally on the valve element, which provides a force-balance valve requiring minimal power for actuation. However, a drawback of this arrangement is that the valve and the shaft, even in the wide open position, create a very large obstruction to the air flow through the runner, which is highly undesirable at high air flow rates in modern engines.
So, in short, the valves theoretically give you a bit more torque down low by increasing flow rate and creating a more homogeneous air-fuel mixture, but subsequently also restrict the flow up top. In pracsis, however, I don't think anyone has noticed any drawbacks by removing the vales. Advantages outweigh disadvantages. I may be wrong though.
Mustang30212
Columbus, Ga.
What are the gains on a n/a bone stock GT??? Any clue?
Thanks for the info..that' answers a lot of questions for me.
RH
tapsport
CMDP
I was wondering about leaving the middle holes open and just tapping and putting a bolt in the end one, anybody ever tried this?? very nice write up!!!
irishpwr46
Official Site Vandal
NYC
i think that would cause a bit of turbulence. its worth a shot i guess though
Casey4s
Woodbridge, Va
Gerardo
This works great for all kinds of stuff, any chrome or polished parts, Drum Hardware etc. as long as the stuff is as clean as you can get it before you Dish Wash it.
Years ago my brother cleaned his 14" Keystone Mag Wheels in his dishwasher one at a time thay cvame out great.
I wouldn't recommend this technique with a woman in the house.
Casey4s
Woodbridge, Va
The set I have I haven't installed yet, I am waiting until Spring for warmer working weather.
Flash_of_Yellow
Lake Stevens, WA
This would be the same logic as drilling holes between all the intake runners in your aluminum heads... don't do it. The fuel injectors inject fuel directly above this point and if you are drawing air into the third cylinder down the block and you have open holes, then it can draw air in from the two adjacent runners (which don't have fuel) meaning it could cause you to run a little lean.
Also, for all of us that remember carburetors, you know that fuel is "sucked" into them by the venturi because air moving at a velocity has a lower pressure than non moving air (same reason a plane can fly). Leaving the holes open can cause this venturi effect to suck air in from the adjacent runners.
06Torch
Houston, TX
Ok, it's been a while now. Have we found out what to use and what to stay away from when performing this DIY? Quick Steel , JB Weld, etc... Does anyone have this mod for over a year? I'm too chicken shit to do this to my car for fear of it coming loose and finding itself in the rest of the motor.
Gerardo
