Trunk wire ID, car alarm wiring ID, car starter wiring ID
KIMMER
Admin
Here's a list of wires, color, and location for the 05, 06, and 07 mustang. This should help for those wanting to do a remote start, car alarm, or trunk button.:thumb:
2005 Ford Mustang Car Alarm and Remote Car Starter Wiring Information
Constant 12V+ Wire: Light Green/Purple
Constant 12V+ Wire Location: Ignition Switch Large Harness
Starter Wire (+): Dark Green
Starter Wire Location: Ignition Switch Harness
Second Starter Wire (+): N/A
Start Wire Location: N/A
Ignition Wire (+): White/Yellow
Ignition Wire Location: Ignition Switch Harness
Second Ignition Wire: N/A
Second Ignition Wire Location: N/A
Accessory Wire: Black/Pink
Accessory Wire Location: Ignition Switch Harness
Second Accessory Wire: N/A
Accessory Wire Location: N/A
Key Sense Wire (+): Light Green/Purple
Key Sense Location: Ignition Switch Harness
Tachometer Wire: NOT Red
Tachometer Wire Location: Use any ignition coil or fuel injector.
Door Lock Wire (-): White/Purple or Orange/Black
Door Lock Wire Location: SJB, black 26 pin plug, pin 3 or 8. The SJB (Smart Junction Box) is in the passenger kick panel. These wire are also found in each kick, in the door harness. The first wire listed is the driver switch wire and the second is the passenger switch wire.
Door Unlock Wire (-): Dark Blue/Light Green or Yellow/Red
Door Unlock Wire Location: SJB, black 26 pin plug, pin 1 or 5. The SJB (Smart Junction Box) is in the passenger kick panel. These wire are also found in each kick, in the door harness. The first wire listed is the driver switch wire and the second is the passenger switch wire.
Door Trigger Wire (-): Use dome supervision wire.
Door Trigger Wire Location: N/A
Dome Supervision Wire: Light Green/Yellow
Dome Supervision Wire Location: SJB, gray 26 pin plug, pin 25. The SJB (Smart Junction Box) is in the passenger kick panel. Also found in the passenger side A pillar.
Headlights Wire (-): N/A
Headlights Wire Location: N/A
Parking Light Positive Wire (+): N/A
Parking Light Positive Wire Location: N/A
Parking Light Negative Wire (-): Black/Light Green
Parking Light Negative Wire Location: Parking light switch or SJB, blue 52 pin plug, pin 31. The SJB (Smart Junction Box) is in the passenger kick panel.
Trunk/Hatch Pin Wire (-): White/Yellow
Trunk/Hatch Pin Wire Location: Truck Light or SJB, black 26 pin plug, pin 15. The SJB (Smart Junction Box) is in the passenger kick panel.
Hood Pin Wire (-): Purple/Orange
Hood Pin Wire Location: Hood Pin or SJB, black 52 pin plug, pin 15. The hood pin wire rests at ground and goes to an open circuit with the hood open. The SJB (Smart Junction Box) is in the passenger kick panel.
Trunk/Hatch Release Wire (-): White/Purple
Trunk/Hatch Release Wire Location: Passenger Kick Panel or SJB, black 52 pin plug, pin 13. The SJB (Smart Junction Box) is in the passenger kick panel. The trunk release motor wire is pink/orange (+) in the passenger kick, harness to rear.
Factory Alarm Arm Wire: Light Blue/Pink
Factory Alarm Arm Wire Location: Driver Kick Panel or SJB, black 26 pin plug, pin 18. The SJB (Smart Junction Box) is in the passenger kick panel.
Factory Alarm Disarm Wire (-): Light Blue/Black
Factory Alarm Disarm Wire Location: Driver Kick Panel or SJB, black 26 pin plug, pin 9. The SJB (Smart Junction Box) is in the passenger kick panel.
Factory Alarm Disarm but No Unlock Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Horn Trigger Wire (-): Dark Blue
Horn Trigger Wire Location: Horn Switch or SJB, blue 52 pin plug, pin 39. The SJB (Smart Junction Box) is in the passenger kick panel.
Brake Wire (+): Light Green
Brake Wire Location: Brake Pedal Switch or SJB, gray 36 pin plug, pin 16. The SJB (Smart Junction Box) is in the passenger kick panel.
Emergency Parking Brake Wire (-): Red/Yellow
Emergency Parking Brake Wire Location: Emergency Parking Brake Switch or SJB, blk 52 pin plug, pin 50. The SJB (Smart Junction Box) is in the passenger kick panel.
2006 Ford Mustang Car Alarm and Remote Car Starter Wiring Information
2007 Ford Mustang Car Alarm and Remote Car Starter Wiring Information
mikek2111987
For anyone looking to do the trunk button, part number D3AY 19C542 A has been updated to F6AZ 19C542 AA. List price now $44.56 and the button is black, not yellow
