Rocket_Burn
- Joined
- Aug 25, 2017
- Posts
- 2
- Reaction score
- 0
Hello all
So I have a friend that purchased a 4.0v6 07 . It had a problem with a its wiring harness insomuch as it had some burned wires in the passenger footwell and had its fan motor jerry rigged the fan to a switch. He found and purchased a replacement harness we spent the greater part of 3 days replacing the internal harness and the motor harness only to realize he didn't get the harness that goes to the lighting and the fan. we put back together what we have with the intention of rewiring the fan to the Bussed Electrical Center. Before we did that though we tried to turn it on and it did refused to turn over. From what troubleshooting I've done it appears to be some sort of anti theft prevention that is not allowing it. What i'd like to know is if this is a correct assumption on my part and if so how to remedy it. If that is not it what on these harness would prevent it from starting.
The Harnesses replaced.
