Modified 05-09 Zimmer Base Turbo Kit
weather man
Persistance Is A Bitch
MN
NO LONGER FOR SALE
OK, up for sale is my USED heavily modified Zimmer turbo kit for 05-09 GT, do not know if it will fit 2010.
This kit is located in Sauk Rapids, MN
First off, I paid a shop to install and tune this kit. You buy this kit, you better know what you are doing or have a shop install. I will not be able to help with installation as I DID NOT install the kit or remove it. You MUST run a custom tune with this kit!
This is a USED kit, it is sold “as is how is”. Look over the pictures carefully before you purchase. It has scratches and dings and it isn’t new. The kit was operating perfectly before I removed for my big ass supercharger kit install.
This is a “Tuner Kit”. You will need to fab exhaust, purchase numerous fiddly bits to make this kit finished and installed.
The turbo mount can be used with a COMP CT4 6765 or the Garrett GT4094R Turbo.
The Garrett turbo was checked over by DB Performance upon removal and is in excellent condition. There is approximately 2,000 miles on this turbo.
The throttle body connector is for a FRPP throttle body.
The kit does not include intake or headers shown to illustrate kit.
The kit includes:
Turbo mount.
Mishimoto R Line Intercooler
Garrett GT4094R Ball Bearing Turbo 1.06 A/R oil/water cooled
Custom Crossover tube for 08 GT
Tial "Q" BOV 5# spring
Tial Dual Sport Wastegates 10# springs
Swaintech Coating on Turbo Hot side Housing
BMR radiator support modified to keep sway bar and support cold side piping.
Ford 39lb injectors ADDED
Oil filter relocation kit minus lines. ADDED
Used unlocked SCT 3 tuner. ADDED
AEM A/F gauge. ADDED
Turbosmart dual port boost controller. ADDED
I am including the turbo coolant and oil line as I have no further use for them. Any hardware to connect to oil pan or coolant system or each other is the buyer’s responsibility.
Hot side and cold side piping as shown in picture, all exhaust beyond that point is up to you. The hot side will end on the back side of K member. I do not know if this kit will clear stock K member. I used a standard height BMR K member.
A memory stick with pictures to aid installation.
One (1) new 3” V band clamp not in pictures.
THIS KIT WILL NOT BE PARTED OUT.
PRICE: $2,500 SHIPPED FIRM PAYPAL INVOICE ONLY
If you want to pick up in person, we’ll talk.
weather man
MN
No piping under a A-arm with this kit.
weather man
MN
Oil filter relocation kit minus lines now included.
weather man
MN
One and only price update.
$2,500 shipped.
weather man
MN
Fucking photobucket extortion
weather man
MN
Fucking photobucket
weather man
MN
Frakking photo bucket
Heaten m90
Extremely interested in this! How much power will it support?
weather man
MN
With turbo cams, FRPP intake and throttle body, I made 707 RWHP at 13 psi. I think anything over 750, a bigger turbo would be warranted. That was on E85. Read the thread completely, what you see is what you get. You will need to fab exhaust, injectors, fuel system. Make sure you add it all up to be complete.
weather man
MN
8 Ford 39lb injectors now included in package.
