Trying to change out my shifter in my 08 Bullitt but the rear won't come passed the hole in the tunnel enough for me to tilt it out. Wtf am I doing wrong. Looks so easy on Youtube. The front of the shifter is also hitting the transmission brace so I don't even know if I can angle it enough once I get the rear passed the tunnel hole.
Update:
Took a whole lot more effort than the videos I've watched. Roush shifter went in from underneath, easy peasy. Trying to get that front mount 10mm bolt started was a fuckin bitch. Shifter linkage was no problem. I sheared off 1 of the 2 rear mount 10mm bolts. What's my options here? Drill it out and replace. Can I run it like it is for a little while?
__________________
Update:
__________________
