Planning a Ford Racing “Aluminator” Build with associated mods over the winter
Scott
King City, Ontario, Canada
Scott I would be honoured to make some of the first passes. As long as you jump in the driver seat after we get it all set up :beerchug2:
I know you still have the drag racing blood in ya, you were drag racing when they didn't print time slips :thumb2:
Matt fantastic! It sounds like a solid plan, but where oh where am I going to find a helmet large enough to fit my fat head? LOL
Scott
Picked up a few more pieces for the build this week:
Circle D Specialties 5R55 Multi Disk 245mm 3000 Stall
Comp Cams, 127550
and Freedom Racing Tool and Die 3V Valve Spring Compressor, FR-303-1039-TD
Sinner
Plano, Tx
What did the stall cost ya? I'm shopping around for ideas for my build and what's the pro and cons of that converter ?
Scott
Ordered the converter from Chris Sehorn, it was $1,100 with free shipping. Circle D Specialties Facebook page indicates they were on for 5% off with free shipping on their Black Friday Sale (Nov 22nd – 27th).
For me based on forum research, it was Circle D Specialties followed by Precision Industries as the converter of choice. However, I do not have firsthand experience with either company.
Scott
Ordered some parts yesterday:
• Trick Flow Specialties Adjustable Crank Sprockets, TFS-51800505
• Trick Flow Specialties Cam Degreeing Kit, TFS-90000
• Trick Flow Specialties Cam Degreeing Lash Adjuster, TFS-90100-Body
• Painless Performance Products Auxiliary Fuse Block with 7 Circuits, 70107
Scott
Ordered some AFCO components yesterday during Lethal Performance's 12 Days of Christmas Sale (15% off and free shipping):
- AFCO 2005-2010 Mustang GT Performance Aluminum Radiator, AFC-81281-S-NA-N
- AFCO Dual Pass Heat Exchanger with Dual Fans, 80280PRO
Scott
Ordered the following from Tousley Ford:
- Ford OEM Cam Followers (24), 3L3Z-6564-BA
- Ford OEM Lash Adjusters (24), 5L1Z-6500-A
and made a tool to install the ATI Damper from a 6" length of M12 x 1.5 threaded rod, a M12 washer, a thick 1/2" - 2" diameter flat washer, 3 M12 x 1.5 nuts and a INA D1-HLA Bearing (needless to say done for a lot cheaper than the 303-102 Ford Tool):
Scott
Picked up these pieces yesterday:
- Painless Performance Products Auxiliary Fuse Block with 7 Circuits, 70107
- Trick Flow Specialties Adjustable Crank Sprockets, TFS-51800505
- Trick Flow Specialties Cam Degree Kit, TFS-90000
- Trick Flow Specialties Cam Degree Suplement Kit 3V Modular 4.6L / 5.4L, TFS-90100
Scott
Closely following tmcolegr’s build thread - a trip to Napa, Home Depot and Lowes provides all the parts required to assemble a Pressure Tank System to pre-lube the engine.
I plan on pre-lubing the engine twice, once during assemble on the engine stand and again once the engine is installed in the car.
When the engine is in the car I will be pressurizing the lubrication system by tapping into my Shelby Performance Parts Oil Pressure Gauge Adapter Kit (part number 5S3Z-9B339-SC).
The adapter block is feed from the OEM Oil Pressure Sensor Port which is after the oil filter.
Because I am injecting the pre-lube oil after the oil filter and as suggested in tmcolegr’s thread I included a 12 microns fuel filter as part of the pre-lube system. The pre-lube configuration consists of the following parts:
- Napa ¼” inlet and outlet Gold Fuel Filter, part number 3001
- WATTS 3/8” Barb x 3/8” MIP Hose Adapter, part number A-294 (Pressure Tank Hose to Shut Off Valve)
- WATTS ¼” Barb x ¼” MIP, part number A-192 (Pre-luble tube to Oil Block Adapter)
- WATTS ¼” Barb x 3/8” MIP, part number A193 (Shut Off Valve to Pre-lube Hose)
- WATTS ¼” I.D. x 3/8” O.D. x 10’, Clear Vinyl Tubing, part number SVGE10
- Aqua Dynamic 3/8” Ball Valve, part number 1107-002 (Oil Flow On / Off Valve)
- RL Flo-Master Sprayer 2 Gallon Translucent White Polyethylene Tank (Clearly would have preferred a 1 Gallon Tank, but try finding one in January)
- Loctite 567 Thread Sealant
Assembled components:
Scott
Picked up the following today:
- AFCO High Performance Aluminum Radiator, AFC-81281-S-AN-N
- AFCO Dual Pass Heat Exchanger with 10" Fans, 80280PRO
- 24 Ford OEM Hydraulic Lash Adjusters, 5L1Z-6500-A
- 24 Ford OEM Roller Cam Followers, 3L3Z-6564-BA
Paladin LL 06
Westchester NY
So I'm searching around the site to see how to install my fuel pressure sensor, and I come across this sick thread. Holy shit, u have more than just cool gauges in your car. Damn, just damn. Good luck with the build, can't wait to see pics of it, or maybe see it in Carlisle PA in June for the all Ford show!!!!!!!
Scott
Thanks for the good wishes on the build!
If you have OEM fuel rails you may be looking for one of these by Metco.
http://www.lethalperformance.com/metco-05-10-mustang-fuel-rail-block-kit.html
Scott
As a goal I would like to have a complete long block ready to do the engine swap and keep the original engine as intact as possible. To that end over the last month or so I have sourced the following used OEM parts:
• Oil Pickup Tube with the Spacer and Bolts
• Windage Tray
• Dipstick and Tube
• Crankshaft Rear Main Seal Retainer Plate and Bolts
• Left and Right Motor Mounts with Bolts
• Knock Sensors with Bolts
• Coolant Tube
• Front Timing Cover with Bolts
• Crankshaft Position Sensor with Bolt
• Camshaft Position Sensors(2) with Bolts
Still looking to buy a Coolant Crossover and VCT Solenoids.
Scott
BIG NEWS, finally picked up the Aluminator short block from storage at DaSilva Racing yesterday. Big thanks to Joe and Matt for keeping her warm and dry for all these months.
Have made some progress in gathering more supplies and parts for the assembly.
Additional Supplies:
• Motorcraft High Temperature Nickel Anti-Seize Lubricant, XL-2
• Motorcraft Metal Surface Prep, ZC-31-A
• Scotch 1.5” Blue Painters Tape, 2090
• WD-40 Company WD-40
• Scott Shop Towels (3 Packages)
• Assorted Sizes of Glad and Ziploc Storage Bags
• Staples 4 ¾” x 2 3/8” Tags, 13035
• Studio Fine Point Permanent Black Markers (2)
Additional Parts:
• Oil Pump Pickup Tube O Ring, F5RZ-6626-B
• Coolant Tube Heater Seals (2), W70593-S100
• 5R55 Automatic Transmission Filter, FT-142
• 07 – 10 3V Coolant Crossover with Gaskets, (Used) Thanks Pat at Steeda Canada
And I am waiting for the following parts on order:
• Oil Filter Adapter Gasket, F4AZ-6840-A
• Oil Filter Adapter Gasket Bolts (4), N806156S437
• Thermostat Housing Gasket, F1VY8255A
• Thermostat Housing Bolts (2), W503279S437
• 5.8L 2013 SVT Oil Pump, DR3Z-6600-A (Thanks to One Eyed Willy's research I am adding the Billet Backing Plate from this pump to my TSS Pump)
• LH 3V Motor Mount with Bolts (Used)
• RH 3V Motor Mount with Bolts (Used)
• Knock Sensors with Bolts (Used)
• Dipstick and Tube (Used)
• Coolant Tube (Used)
Stay tuned for short block pictures once I find someone to help me lift it onto the engine stand.
ILW84U
Edmonton, Alberta
Hey Scott. I think you still need a fuel system for your build. :naughty1: :poke2: :whistling:
Nice to see you are ready to start building.
Scott
Rick, you are right there may yet be a return style fuel system in my future. Will be degreeing the cams soon and may take you up on your offer for moral/technical support. lol
Epic build
Good Luck
Thanks!
