Finally some Boost!
richman
WTF!!! AGAIN AMERICA?
Michigan
Well got my grinding hat back on. All the sound deadening should be gone by days end. Took a break and scooped out some.
1.6 pounds ( not including plastic container of course)
richman
Michigan
Well I'm finally done with the grinding crap out of my car. Just some cleanup and removal of Transmission and driveline. Install the doors and off to paint.
richman
Michigan
4.4 lbs gone. Not sure why these have to be so heavy.
richman
Michigan
Stock driveshaft is a heavy bitch! Will replace with 2013-14 GT500 CF Piece.
Wes06
agreed on the driveshaft, I used my jack on the carrier bearing to support the majority of the weight when it disconnected and slowly lowered down while i pulled it back.
put a DSS in mine
richman
Michigan
13.6 LBS not going back on car. Will run stiff spring rates on all four corners and the thickest front seat bar I can find. Rear sway bar is bye bye.
slackinoff
East Texas
What are you using the car for?
Sent from my LG-H910 using Tapatalk
slackinoff
East Texas
Just want it to put a smile on my face every time I get in it.
Arnt we all! [emoji6] But why take off the rear awaybar? Are you improving the handling with stiffer springs and it's just not needed?
richman
Michigan
Yeah road course duty. Gonna be a weekend fun toy that I take to the track 4-6 times a year.
richman
Michigan
What rear spring rates are you looking to run, out of curiosity?
Probably 350 lb in rear. Not sure what I will run in front. Haven't decided on which suspension I will be running tbh. Just looking at different brands and weights ect.
fourdegrees11
AZ
Awesome build man. Photobucket really ruined this thread though, first 75% has no pictures anymore :(
richman
Michigan
I will go threw the entire thread and repost all pictures. This thread is so when I forget what the hell I did so can go back and see where I fucked up! Should be back up in a few days
richman
Michigan
Alright small update.
Been busy with the starting of my own LLC and what not. Not much has been done to car. Still ripping stuff off. Almost done with that. Suspension is stay on for now so I can roll it to the paint shop via flat bed.
Still not time frame from DOB for new intake for the 5.4L engine so I'm in absolutely no rush. Just working on it when I want to.
Starting to collect parts but I'm doing a lot of homework on each component. I only want to build and buy this one damn time!
I'm going to look up to see if there is a IRS out there that is lighter then our live axles for the S197. Seems to me that I remember a company that made one a wile back. Since a properly set up live all can out perform my driving skills it's not a must.
Mirrors are being replaced. These come in at 4.3 lbs.
richman
Michigan
Bump stops come in at .7lbs. I'm not going to grind the mount off the axle tubes yet because I may replace it with a 13-14 GT500 set up.
richman
Michigan
Alright. .... all photos have been updated from the pos photobucket crap.
richman
Michigan
Kind of a lot of work just to shed 0.1 pounds. Oh well.
richman
Michigan
Not deleting power steering but I will clean this up and replace what needs to be replaced to make it like new again.
Side note, those bolts are the first I actually had to break out my high impact Milwaukee for. Everything else I have used the mid torque.
