Specs / torque values, in OEM PDF files + Shop Manual Link
mpf
Naperville, il
jsnyng
Alpharetta, GA
Attached is the 2011 Ford Mustang Owner's Manual.
  • 2011 Ford Mustang Owners Manual.pdf
bestmustangparts
I'm looking for the main cap and rod tq angle instructions. Is it in there?...if it is, I'm not looking in the right place.
1fast05
I wanna go fast
Gulfport Ms
The links is basically useless it doesn't give you the torque or angle spec, just says go to the procedure
Jefro
OKC, OK
Yeah, I've had to reference the shop manual a lot in the last week. Thanks for posting!!
gottoast
Buffalo NY
Wish I would have found this post on my phone last weekend when I was under my car re-torquing everything!
Thanks for all the information this is great!
Frankief28
Brooklyn
Hey I did a 2018 manifold swap on my 2012 however my old engine cover does not fit anymore . If I buy the 2018 engine cover would it fit? Thank you
07gts197
Naples, Fl
Why would you want it? I think it’s ugly, it’s like one on a Mercedes that covers the entire motor almost. I guess to each their own. So yeah I don’t see why it wouldn’t fit.
ACME RACING TEAM
A few PDF files from the non-working original links ( PDF's below )
Does anyone have the Service Manual for 2011 - 2014 Mustangs (5.0L ) ?
The link above does not work and the Wayback Machine doesn't have it.
Thanks !
  • driveline lubes.pdf
  • engine specs & torque values.pdf
  • FordInstShtM-6007-A50NA.pdf
  • jacking and lifting.pdf
  • mt82 specs & torque values.pdf
  • suspension specs.pdf
  • vin decoder.pdf
