- Joined
- Dec 17, 2009
- Posts
- 62
- Reaction score
- 1
BMR Suspension Poly Bushing Vertical Link for the 2015-Newer Mustang
TCA048 - $99.95
TCA048 - $99.95
Launching harder, reducing wheel hop, and adding cornering consistency to your 2015-newer Mustang is easy with Vertical Links from BMR Suspension. Stock stamped steel vertical links with soft rubber bushings deflect under load, absorbing power and allowing excessive spindle rotation. Manufactured from heavy-duty 0.75-x1.5-inch boxed tubing, the tubular construction eliminates vertical link flex. The arms are completed with 95-durometer polyurethane bushings, solidly linking the spindle to the lower control arm. The BMR Vertical Links (TCA048) will stand up to the high loads of any performance environment. These are the perfect upgrade for the enthusiast looking to greatly improve performance without big increases in NVH. Designed to excel in street performance, drag race, and road race applications, the TCA048 tremendously reduces vertical link and bushing deflection, increasing rear wheel alignment consistency. BMR Suspension’s TCA048 tubular polyurethane Vertical Links are available in black hammertone or red powdercoat for long-lasting good looks. Installation time is about 2 hours. Proudly made in the U.S.A.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
