Is a v6 Rear end a 8.8 or a 7.5?
Kevinmach1
Major Member
Iowa
Is the rear end in the 2006 v6 s197's a 8.8 or is it a 7.5? Its a vert if that matters....
Just wondering so I can do a possible gear swap with some 3.55's I already have...
Thanks...Kevin
4LiterSonic
Banned
Pitstop
Weak-ass 7.5.
Just buy the 8.8. It'll be way cheaper in the long run.
On a side note, what does the number notate? The thickness of the axle?
Ken04
gm troll basher
Santa Rosa Ca.
double post, mother effin, hunk of shit computer,,, hahahahaha
Ken04
gm troll basher
Santa Rosa Ca.
Weak-ass 7.5.
7.5 equals 7 1/2" measured across. The 7.5 is fine unless you start building alot more power. I would add a T-Loc of some sort while you swap out gears. The trans is a weak link also over 300 hp, so unless you're going to upgrade the trans, clutch, driveshaft and rear end, leave it, drive it, love it.
Kevinmach1
Major Member
Iowa
Well shucks... I have a 3.55 and a T-loc both for an 8.8.... I hoped it would work.
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Get an empty 8.8 housing and put them in!
Just be careful making slow left-handed turns on slippery surfaces with the stock 7.5; many a peeps have spun out and lost control. Adding a t-loc or putting in a 8.8 solves that issue as well.
The weak link on the 7.5 when you get to adding more power is the spyder gears. They tend to break. The tranny is tough enough for most people, even with a power adder.
DraggnRoush
Jimi Hendrix Blues
NYC
I put a "New Take Off" 8.8" axle with 3.73 gears in my V6 for about $600. Got gearing and T-loc and beefier rear end all in one package. QED.
Ken04
gm troll basher
Santa Rosa Ca.
going to a 3.55 from 3.31 wouldn't do much for you anyway. If you're going to spend the money for the install kit and the labor, go 3.73 or 4.10. You'll really feel the difference.
Ken04
gm troll basher
Santa Rosa Ca.
how do you spin out making a slow turn, and how do you spin out with an open diff ? Explain plz.
