WTB clutch pedal wire harness from manual s197 car
swflastang05
Back for More
N. Ft. Myers, FL
I'm looking for the wiring harness that includes the clutch pedal position switch, cruise deactivation switch, and aux relay #2 assembly from an original manual transmission car. It connects to c215 behind the instrument cluster, let me know if you have one..looks like this
I think this is the same harness 05-10 v8 cars, maybe even through 14, although it's for my 05 GT.
Jkoogler
I got most of but I cut on connector off it sorry if most of it will work you can have it
Jkoogler
I actually found it all I can put it back together for you and you can have it just pay shipping
swflastang05
Back for More
N. Ft. Myers, FL
I'm not sure, it does detach from the main harness above the dash, connector located @ the fire wall behind the instrument cluster. IIRC it's C215.
swflastang05
Back for More
N. Ft. Myers, FL
That is strange, it doesn't have the aux relay #1 assembly. Everything else looks pretty much the same. There were a few wiring changes from the 05-06 cars to 07, that must have been one of them. Thanks for responding though!
white_lightning
Calgary, Alberta
Sorry I couldn’t help. I did a GT500 engine swap into my GT and swapped all the wiring too. I thought for sure I’d have a spare that would work for you!
lphill01
Las Vegas, NV
swflastang, I have one from an 06 GT manual, White_Lightning, I'm actually trying to find an 07 version, do you still have it by chance?
