WTB Two Wire Connectors from Seat Buckle Assemblies
Scott
King City, Ontario, Canada
Looking for a two connectors from 2007-2013 Mustang Seat Belt Buckle Assemblies. The part number for the buckle assembly is 7R3Z-6361203-AA, but I only need the male two wire connectors with 3 or 4” of wire.
o2sys
NY/NJ
I may have an extra manual seat harness, I can check when I get home tonight.
Scott
Mario thanks! I need a couple male connectors that mate with this seat harness connector.
Jkoogler
which ones are you needing? the ones in the wiring harness or the ones that are on the actual unit.
o2sys
NY/NJ
Here is the harness I have. It doesn't have the connection you are looking for:
Jkoogler
I pulled out my 05 harness I didn't see anything that looked like it have a picture of the end close up
o2sys
NY/NJ
They look like o2 sensor plugs. Maybe you are better off buying o2 extender wires and using those instead.
