DMCC Drift Car build
fivehunsky
Whats up man? Its Aaren from Texas. I just saw this subforum and Im about to start my thread as well. I decided to do the rear mount radiator as well.
Anyway, Im still considering those panels :)
Car is looking great!
tr_racing
Quebec
Yeah, I'm happy to have a subforum as well. The radiator in the trunk is supposed to balance the car near 50/50 :) Will see :p
Kevin
Ch4r1ie
The Limey Bastard
Down Under
Kevin
Yeah, i get the weight distribution thing, but how does it cool with little to no fresh air flow over it it?
tr_racing
Quebec
I have never test it myself, but ASD Mustang (Monster one & Falken Tire) have both rear mount radiator & have no heating problem! I will test it with the stock water pump, if it's not working I will swap it with an electric one!
You need to do ducing & have a strong fan setup, my fal fans is pulling 6000cfm hope it will be enought !!!
Kevin
Ch4r1ie
The Limey Bastard
Down Under
Kevin
I'll definately be interested to see your results mate :thumb2:
Sideways mounted roof scoop? :naughty1:
What?
I have them as part of my setup the airflow through them is not huge :beerdrink:
irishpwr46
Official Site Vandal
NYC
i wonder how much it would help if you put these over them and opened the front to make it functional?
tr_racing
Quebec
Hey Guys sorry for the lack of updated, but I was nothing to put on, since we have been busy in making the mold for all the fiberglass parts.
So I have receive some nice parts, rear BMR suspension parts:
Racepak & OBD2 harness (hope it will work fine with my Ford Racing ecu)
I decide to check a little for the steering angle on this cars, I did three step, oem, no stopper & 7mm rack spacer, look at the pictures:
This is still w/o modified knuckle but can't wait to put them on when I will receive it :) But I think I will have to modified my lca for more clearance!
Kevin
braupe
Resident Diabetic...
The Fort Worth side of DFW
Kevin
That is awesome! I can't wait to see the finished product.
Where is the stock stopper located?
tr_racing
Quebec
The stock stopper is located between the inner tie rod & the rack. It's a white plastic C Clips that is easy to be remove !!!
Kevin
tr_racing
Quebec
Hey, this week-end we have progress more, we finish front & rear tubular bumper, finish front light & bumper bracket, put the Standard suspension coilover on & rear suspension arm.
The Standard R1 Suspension with custom spring rate:
GC camber/caster plate:
Rear suspension arm:
We test the ride height, but need to raise it again a little to have more ground clearance for the side exhaust, etc
Rear tubular bumper:
more to come....
Kevin
