Check engine lght came on llast nigh???
247idot
Last night as i was driveing home and the check engine light came on its a po172 code i looked it up and found out that its running to lean on bank 1. What should i do to correct this for good?? Help would be greatly appreciated.
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Your car is wanting my sway bars...LOL...good luck in figuring it out!
GIG4FUN
Rock 'n' Roll Moderator
Iowa
I HOPE this doesn;t turn into a chat thread... :whistling:
I'm just sayin' :oops:
Aandf1978
M90 SUPPORTER!!
Virginia Beach, VA
P0172 is actually running too RICH on bank one. Here is something to start:
Inspect all vacuum and PCV hoses, replace if necessary
Clean the MAF sensor. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
Inspect fuel lines for cracks, leaks, or pinches
Check the fuel pressure at the fuel rail
Check the fuel injectors, they may be dirty. Use fuel injector cleaner or get them professionally cleaned/replaced.
Check for an exhaust leak before the first oxygen sensor (this is unlikely to cause the problem, but it is possible)
Ken04
gm troll basher
Santa Rosa Ca.
good answer, to the OP, some due diligence is due on your part. You will need to open the hood and do a thorough check of all lines and connections. Too lean usually means a vacuum leak. Too rich as AandF1978 said is something else. So before you say; "I got a code, what's wrong" you need to rule some things out first so the smart people in this forum, of which I am not one, can help you.
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Check your PCV hose and valve, too; it's on the passenger side. It shouldn't throw a code, though.
Bank #1 is passenger side.
In addition to what's been suggested, check your air filter; replace or clean it if dirty. And definitely clean the MAF, with proper chemicals.
Also check your EGR to make sure it's not cracked or leaking (sucking air in).
