- Joined
- Dec 17, 2009
- Posts
- 62
- Reaction score
- 1
BMR Suspension Drag Race Lowering Springs for 2015-Newer S550 Mustang - SP086
Improve the cosmetic appeal and weight transfer of your S550 with Drag Race Lowering Springs from BMR Suspension. Manufactured from chrome silicon high-tensile spring wire, these springs are cold wound on a CNC coiling machine that can adjust the spring diameter in real time to ensure that every spring is exactly the same. These springs will lower your 2015 and newer V8-equipped Mustang and feature a 150 lb/in front and 800 lb/in rear linear spring rate to give you a smooth ride, improved weight transfer, and great looks. The BMR Lowering Springs (SP086) allow the front end to rise easily, transferring weight to the rear tires for increased traction. The rear springs are stiff enough to handle higher loads, while remaining soft enough for a comfortable ride on any road. BMR designed the SP086 springs for drag race applications, but it also works well for the street. Front and rear versions are also sold separately (SP087 front, and SP088 rear).Like all BMR lowering springs, the SP086 has a LIFETIME guarantee against spring sag. Available in red powdercoat for long-lasting good looks. Installation time is about 3-4 hours. Proudly made in the U.S.A.!
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
