BMR Suspension New Product Xtreme Anti-roll Bar w Delrin Bushings for S197-XSB011
BMR Suspension
BMR Suspension Xtreme Anti-roll Bar with Delrin Bushings for S197 Mustang
XSB011
Hard launches from high horsepower cars at the drag strip require more that just a normal street-style sway bar. BMR Suspension’s Xtreme Anti Roll Bar for 2005-2014 Mustang or 2007-2014 Shelby GT500 allows you to launch harder without excessive body roll limiting traction. Manufactured from heavy-wall 1.375-inch DOM tubing, BMR’s Xtreme Anti Roll Bar (XSB011) is designed to eliminate body roll and transfer as much power as possible to the rear wheels. The XSB011 attaches to your Mustang with solid Delrin bushings. These bushings are CNC-machined from Delrin, and eliminate all bushing deflection. The fabricated laser-cut, steel sway bar arms are reinforced to add strength and minimize deflection. BMR Suspension designed the XSB011 sway bar for drag race and limited street applications. The large adjustable sway bar has three positions, giving you the versatility to drive to the track and race at the track with the same sway bar. The XSB011 gives you as much as 4,090% increase (2,430%, 3,080%, and 4,090%) in rate over the stock bar (depending on year and model). These rate increases and added adjustability allow you to eliminate most body roll so you can leave the starting line harder with maximum traction. When performance is a must, rely on BMR Suspension! BMR Suspension’s XSB011 anti roll bar is available in black hammertone and red powdercoat for long-lasting good looks. Installation time is about 1-2 hours. Proudly made in the U.S.A.!
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
JLear
2014 GT
Central Kentucky
Is this the bolt on model y'all have been developing recently?
Edit, just read the installation instructions and answered my own question lol.
BMR Tech
Traction Vendor
Tampa, FL
Really hard to say. When not lubricated, the noises will be somewhat different....yet very loud and noticeable. When lubricated, not much noise at all.
When talking ARBs...the noises you will get are from the mounting end links with spherical/Rod-Ends. Rarely does a noise from the bushing ever become apparent.
I am trying to get a vid loaded to You Tube to show some impressive results with this XSB011 on a pretty fast TVS Coyote (9.0@153) - hopefully I can get it loaded soon.
