I have 275-40-18's on the front of my 2010. With Roush springs + oem struts, its 1/2" lower. (With roush springs + roush struts it was 1" lower, busted a strut, and replaced both struts with oem struts).
Looking at your pix (and u are also using 275-40-18) I'd say you have way less than 1/2" drop...looks like stock ride height to my eye. I have less tire to top of wheel well gap..and that's with only a 1/2" drop. What is your distance from ground to wheel well arch ?
So sky render may well be better off with K springs...which are also a little stiffer vs P springs...both front + rear. Even then, with the Vorshlag kit, + K springs, he might be looking at 1/2" - 3/4" drop tops. Jason may well have the answer.
It's 28" from the ground to the wheel well arch, and 15 1/2" from the wheel well arch to the center of the wheel. That first number is going to vary somewhat depending on what size wheels and tires you use. Same measurements front and rear, the car sits level.
The car definitely is lower than stock (non-Brembo 2011 GT) but you are right, not by a lot.
I suspect Bilsteins tend to raise the ride height a little due to being high pressure charged. I know dampers aren't supposed to affect ride height, but there are a lot of anecdotal reports of this.
EDIT: Concerning the P vs. K I think Ford reports the P lower 1" and the K 1.5". The P reportedly are a little stiffer in the front and softer in the rear compared to the K, although consistent spring rates are hard to come by.
