S197 Mustang Forum - S197Forum.com
Go Back   S197 Mustang Forum - S197Forum.com > Mustang s197 Tech Forums > DIY Tech Guides
DIY Tech Guides Come here to post or look for a walkthrough guide for anything from installing s/c's to changing oil. It goes here!
Reply
Thread Tools Display Modes
Old 10-26-2014, 05:34 PM   #1
onehotpny
onehotpny's Avatar
onehotpny is an unknown quantity at this point
Default 2005 power windows switch wiring diagram
Thanks to BruceH I was able to download the 2005 power window switches diagrams, Here's my contribution after color coding the wires to make it easier to see... I didn't do the convertible diagram.. I'll do it tonight and post here...
Drivers side
Click the image to open in full size.
Passenger side
onehotpny is offline   Reply With Quote
Old 08-10-2017, 08:54 PM   #2
slackinoff
slackinoff's Avatar
slackinoff is an unknown quantity at this point
Default
Ok question. I am not good at reading wiring harnesses first off. If you have seen my thread on installing Scott Rod door panels, you know I am trying to relocate the window switches to under the steering wheel consol. Now seeing as I already rivited the new panels in place, I would like to avoid drilling the rivets out to pull the wires through the door into the cabin.
So here is my question.....Can I find and intercept the window switch wires INSIDE the cabin?......beacause from the looks of the diagram, it looks like the window switch goes right to the window motor and does not go back into the cabin.....
__________________
Rm
Instagram: Probuildmustangs
slackinoff is offline   Reply With Quote
Old 08-10-2017, 08:59 PM   #3
slackinoff
slackinoff's Avatar
Default
Looks better in personClick the image to open in full size.Click the image to open in full size.
Sent from my LG-H910 using Tapatalk
__________________
Rm
Old 08-11-2017, 07:53 PM   #4
slackinoff
slackinoff's Avatar
Default
No ideas on if the window switch wires make there way into the cabin....so that I can intercept them? I am afraid they go straight from the switch to the motor......help!
__________________
Rm
Old 08-11-2017, 08:47 PM   #5
Wes06
Wes06's Avatar
Wes06 is an unknown quantity at this point
Default
pretty sure they go in to the SJB then back, or maybe signals just come in for the window to step it down when opening/closing
__________________
Quote:
Originally Posted by skwerl View Post
You're doing it wrong. I have no idea what you're doing wrong but it's wrong.
My rear opening isn't near as large as Cam's but it will still hold a quart size bottle of brake fluid.
Wes06 is offline   Reply With Quote
Old 08-13-2017, 07:35 AM   #6
slackinoff
slackinoff's Avatar
Default
Quote:
Thanks! I need to remove what I think are the amps for the door speakers (shaker500). Both are right where the drivers side door harness comes in.....that would allow me to intercept them there instead of the SJB.....which is on the other side of the car and not where I want my switches.
__________________
Rm
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Ad Management plugin by RedTyger
