JimC
Came to terms on the results of the inspection on our place in Winston-Salem and what we want the seller to take care of. One item was left today and the seller came back with an offer that was acceptable to us on that. So on track for closing at the end of July.
Then my wife will move down, with the furniture, in the fall. I'll get a small place in Michigan until I retire again and head down on weekends and in warm weather (if I haven't retired yet) she will come up occasionally to be with me and get away from her sister.
Gabe
Whippled Coyote
Pavers done - new sod & sidewalk tomorrow
That looks awesome!
tjm73
of Omicron Persei 8
Rush, NY
I'd skip all that and go LED. Just retrofitted all the fluorescent lights in the basement and garage, much brighter, lower energy consumption and longer life spans.
I'm looking to go LED in my garage. Eight 4ft bulbs. If it's damp or cold they sometimes don't light. If it works out my barn will get the same.
oldVOR
Northern Virginia
If you presently have fluorescent fixtures, you can strip out the ballast, wiring, tombstones and lamps. There are several kits that will retrofit right into the fixture shell. I do not recommend just changing to the four foot tubes that have LEDs inside and re-use the fluorescent ballast. The ballast can overdrive those conversion tubes and shorten their life cycle.
tjm73
of Omicron Persei 8
Rush, NY
Hmmmm. Good to know.
I was going to get the ones that work off the ballast and be done with it.
Yea, single car is te norm around me. I also really don't have the room to,add to the right as u face the house. The property line cuts in at an angle.
ZmanM3
The Evil One
Jackson, NJ
I feel your pain, this stupid town house we live in with a single car garage sucks.
Gabe
Whippled Coyote
Dave, that looks awesome dude.
Yesterday I spent a few hours in the morning cleaning up more of the brush from the back yard, did another 2 trips bringing it to the local dump.
Got done with that, decided to move a big boulder in the back yard, since it was not in a convenient spot.
Hooked up the truck to it using a large ratcheting tow strap, dragged it into its new home, thought I was gonna be able to unhook,
pull forward and to the right, then back out of the spot I was gonna head into.
Turned out the truck was longer than I gave it credit for, and with a worse turning radius.
So it looked like the truck was gonna become a part of the back yard for a while.
Couldn't back up much since big rock was now back there, other big rocks and trees already back there too.
And more stuff in the front.
Luckily I was able to move some smaller big rocks from the front, and after about a 15-point turn,
a new dent in the rear bumper from a tree that popped out of nowhere, and a torn-off front mud flap, truck was free again.
Parked it on a nearby dirt mound, just because.
Thanks Gabe - that's a lot of work,I have done in that yard.
Yesterday - cleaned the gutters, checked the spinklers pattern on new heads after the pavers, found they put a spike through the irrigation line by the new sidewalk, could fix it, no parts and didn't feel,like digging up enough grass and soil to get to the hole.
MSgt46270
That came out looking good.
Later on the first part of 2018 we plan to add pavers also. I hate the way the left side of the house looks. My friend Joe and I dug out a lot of dirt to start getting it ready for later on. But before doing the pavers we need to replace the main water line shut off valve due to leaking only when you turn it off or on mid point (easy fix). Then we need to run a water drain from the back yard to the street.
MSgt46270
What's the damage $$$-wise on that project if I may ask? Looks awesome.
Home depot sales pavers and if you get them by the pallet you'll get it at a discount. And if your a veteran you should be able to tack on the 10% discount???
Premium08
Need to Get Another Pony
Littleton, NC (Lake Gaston)
Been baffled at why my dishwasher was leaving some dishes dirty(mostly glasses and mugs). Went to unload it yesterday and almost everything had food residue on it. Started investigating and saw that almost all the water nozzles were clogged with food. Spent the next 30-45 mins trying to get all the food out the nozzles with a pick and compressed air.
Sent from my XT1585 using Tapatalk
tjm73
of Omicron Persei 8
Rush, NY
My driveway is 9-10 feet wide and about 485 feet long. Blacktop will happen before pavers. In fact blacktop is the long term goal. Right now it's all recycled blacktop millings. My driveway guy said they will make a great base when we decided to add blacktop as they will compress between now and then and make a stable hard base.
bujeezus
Alabama
That's why we don't even use a dishwasher. Good old fashioned hand washing...
Dad
SW KY
Have you cleaned the filter? And run a couple cups of bleach through the thing?
