Livernois Motorsports Built 298 Stroker and ProCharger Build
Dearborn Heights, MI
Another great build coming through the doors of Livernois Motorsports. This time it’s a 2008 Ford Mustang 4.6L Roush for some major upgrades.
We’re starting with our Livernois Motorsports Pro Series 298 Stroker long block to make a great base to build power and support the ProCharger D1SC.
Other Mods included:
Livernois Motorsports 4.6L 3V 9.4 to 1 Pro Series Short Block
Livernois Motorsports Powerstorm Billet Oil Pump Gears
Livernois Motorsports Powerstorm Stage 3 Pro Series Blower Cams
Livernois Motorsports Crank Scraper
Livernois Motorsports MyCalibrator Tuner
Livernois Motorsports Custom Dyno Tune
Livernois Motorsports Powerstorm Stage 2.5 Heads
Long Tube Headers
Upgraded Balancer
FRFP Fuel system
ID850 Injectors
McLeod RST Twin Disk Clutch
Full 3” Exhaust
And much more!
The injectors and fuel pumps were replaced for an E85 converison but starting with a 93 octane tune to see how much it will make!
Stay tuned fro more results!
For all your performance installation needs, contact Livernois Motorsports TODAY!
(313) 561-5500
[email protected]
www.livernoismotorsports.com
Base line testing is done and stock power numbers are in.
Made: 399whp and 388wtq
Motor has been pulled today and getting ready for the new Powerstorm Pro Series 298 Stroker!
Motor is ready! Waiting on some final components and it will be in the car in no time.
We double keyed the aftermarket damper and the crankshaft, a service we do here for a couple reasons. We place the second key 180 degrees from stock to ensure the damper does not spin off the crank at the snout. This also helps as a safety adder, to not rely on the stock single key for engagement.
Gabe
Whippled Coyote
Really like you guys, but the name powerstorm ... Not so much
The Livernois Motorpsports Powerstorm 298 Stroker has made it into the car! We will be adding the ProCharger and some of the other mods at this time, then its off to be tuned! Can't wait to see the power output.
Our custom Livernois Motorsports CNC'd valve covers make a great touch to this build. Some under the hood bling to match.
weather man
Persistance Is A Bitch
MN
Nice touch on the valve covers guys.
Gabe
Whippled Coyote
Did you guys cause a storm inside that building?
A power storm?
