I wonder if you could get a few more MPH by switching to something like the Tiger Racing Hood and doing some more aero stuff.
1/4 mile mph seems low for the power level. DA must have been super high with the bad weather and being in the mountains.
I agree. With 500 rwhp it should be around 117 mph in 1/4. Even at 2000 DA it would only impact it by 1 mph or so.
That is what I thinking. I guess it all depends on rear gears, transmission gears and shift points as well as horse power and Driver's lack of skills.
Going again in Sept
What kind of gauge pod is that?
did you datalog any of your runs? just curious. but your numbers are closer to 375 rwhp at your weight level, was curious if the car was pulling timing and what was the coolant temp and air charge temp by the end of the 1/2 mile.- stone stock coyote cars run 108- 111 in the 1/4 and there basically 345-360 rwhp from the factory depending on transmission trim
Did any of our Mustangers go to the NC 1/2 mile this past weekend? I want to hear some results.
Did you get your white smoke issue figured out?
good deal- kinda sucks having to do it twice- I was hoping it was a breather issue(couldn't be that lucky) I wanted togo to the either of the Georgia ones this year but I have prior engagements- The VA one has a altitude of I think almost 4000' - that just scrubs off numbers-This is why I didn't register for that one. I am use to running in 750' and below elevation. Airstrip attack has one in Marion IN in August and registration opens Monday July 3rd- I am pretty sure I am going to register for this one - Plus it is only 2.5 hours from my house where as the Wanna go fast events are all 10+ hours- except the IN one in October- which is still 5 hours away- Good luck with engine rebuild and running in September.
Found the problem and getting rectified, rings didn't seat on last engine build, should have used a shop that build yptheie own engines not a tuner who out sourced it.. Getting rebuilt at Fastlanes Motorsport. Will be ready in time.
