S197 Mustang Forum - S197Forum.com
Go Back   S197 Mustang Forum - S197Forum.com > Mustang s197 General Forums > Mustang Chit Chat
Mustang Chit Chat Want to talk Mustang but it isn't tech? Do it here
Reply
Thread Tools Display Modes
Old 06-19-2017, 04:48 PM   #1
Yoyo1
stangester
Yoyo1's Avatar
Yoyo1 is an unknown quantity at this point
Default Royal Purple Synchromax Trans oil
Royal Purple Synchromax Trans oil.
Ok. I apologize ahead of time. This issue has come up b4. But I desire definitive answer . . . if there is one.
Many say its not good for the 2008 Mustang GT. I read this S197 model is a T-3650 transmission . . . not sure if this is correct.
Many say its good for this car.
Throughout this forum, I read some good stuff and some bad stuff. Many seem to say use Mercon 5.
Final scoop...RP Synchromax good or bad?? I just want to make sure it won't screw up the car and is not worse then factory recommended fluid.
Thoughts? Yes, I already ordered it and LMR won't cover S&H if I return it. Lol.
Yoyo1 is offline   Reply With Quote
Old 06-19-2017, 08:00 PM   #2
06 T-RED S/C GT
06 T-RED S/C GT's Avatar
06 T-RED S/C GT is an unknown quantity at this point
Default
I suggest you read the rules of this forum.. Threads such as this belong in the chit chat sub forums, not technical !
__________________
2006 GT - Saleen series VI S/C - 39lb injectors - 3.6" pulley - UPR 4ch catch can - CFM billet valve cover breather - Hurst short throw shifter - Koni sport adj struts/shocks - GT500 strut mounts - FRPP 4:10 rear axle gears- Saleen extreme 98mm MAF lid w/stock airbox- Brenspeed 91 oct Saleen calibration - Eibach pro springs - BMR poly adj panhard bar..
06 T-RED S/C GT is offline   Reply With Quote
Old 06-19-2017, 08:03 PM   #3
stkjock's Avatar
stkjock has a reputation beyond reputestkjock has a reputation beyond reputestkjock has a reputation beyond reputestkjock has a reputation beyond reputestkjock has a reputation beyond reputestkjock has a reputation beyond reputestkjock has a reputation beyond reputestkjock has a reputation beyond reputestkjock has a reputation beyond reputestkjock has a reputation beyond reputestkjock has a reputation beyond repute
Default
There isn't one
Moved
__________________
Corn Fed - Shelby GT500 - Fast Car-Slow Driver
L&M Engines Built Motor-Lund Racing Tuned-4.0L Whipple Charged
stkjock is offline   Reply With Quote
Old 06-19-2017, 09:59 PM   #4
Yoyo1
stangester
Yoyo1's Avatar
Default
Good grief 06 TRed..GT...lighten up. Its just a question. Sorry if it offended you! Lol...kill me im a newbee.
Old 06-19-2017, 10:29 PM   #5
RocketcarX
95% of my weight is fuel
RocketcarX's Avatar
RocketcarX is an unknown quantity at this point
Default
Royal Purple products belong in the trash
__________________
Stealth Fighter Status
"We go together like cocaine and waffles" - Cal Naughton Jr.
RocketcarX is offline   Reply With Quote
Old 06-19-2017, 10:48 PM   #6
Yoyo1
stangester
Yoyo1's Avatar
Default
Yes...from this forum and others looks like RP is not too good. Wow, its kind of odd as it gets good reviews on certain websites.
Old 06-19-2017, 11:39 PM   #7
Phil1098
Phil1098 is an unknown quantity at this point
Default
For what it's worth, I called Tremec and asked them what to use in a TR3650 and without hesitation he said Mobil1 ATF. Said that's what they use.
__________________
2006 GT FRPP CAI, Kooks LT headers, Kooks OR H, FRPP FR500S mufflers, FRPP Hot Rod cams, Steeda UDP, Eibach sway bar kit, Whiteline LCAs, CMDP, MGW shifter, Tuned by Lito
Phil1098 is offline   Reply With Quote
Old 06-20-2017, 12:32 AM   #8
SVT Rider
SVT Rider is an unknown quantity at this point
Default
Correct, the TR-3560 was qualified as a transmission with Mobile 1 Synthetic ATF (meets Dexron-III and Mercon-V specs), and Ford went with their Mercon V since it already was a fluid Motorcraft supplied and used. Mobile 1 is a great upgrade for better shifting feel and high/low temperature stability.
__________________
2007 Mustang GT Premium, 5 speed manual, Grabber Orange
K&N "Short Ram" CAI, 3.55 gears, Ford Racing Suspension (M-FR3-MGTA) w/ "K" springs, Vorshlag Caster Camber Plates, JBA 3" axle-back exhaust, UPR Oil Separator, 18" Shelby GT500 Wheels w/ 275/40ZR18 Hankook Ventus Evo2 tires, Shaker 1000 Audio System
SVT Rider is offline   Reply With Quote
Old 06-20-2017, 12:57 AM   #9
06 T-RED S/C GT
Default
Quote:
Wasn't offended at all newb lol. Just providing you with a heads up
__________________
Old 06-20-2017, 09:42 PM   #10
Iceman62
Bullitt 6005
Iceman62's Avatar
Iceman62 is an unknown quantity at this point
Default
Once you get the Royal Purple oil, pour it on weeds in your yard. Then go to the auto parts store and get ya some M1 tranny fluid. ;) :D
__________________
32-Degrees = Iceman is "In the House"
MSgt, USAF (Retired)
Iceman62 is offline   Reply With Quote
Old 06-21-2017, 02:36 PM   #11
BruceH's Avatar
BruceH is on a distinguished road
Default
The theory per Tremec is that they never tested with RP so they can't recommend it. It's been reported than not only RP but other transmission fluids will delaminate the syncros over time. Nobody really knows AFAIK.
I've used it and it worked just fine in my 3650 as long as the temps were summer like. As soon as it got chilly the trans would need to be shifted very slow until the fluid warmed up.
If you want to use RP then use the ATF. It has all the testing and certs to be used for ATF and ATF is what is speced by Tremec.
As for the bad press it mostly comes from places or people who sell a boutique lubricant. RP can be purchased anywhere and it eats into private sales of boutique dealers. At least that's my take on it.
__________________
Big Bore Boss custom build N/A with TR6060 and whole lot more.
For sale: $13.5k http://s197forum.com/forum/showthread.php?t=132246
BruceH is offline   Reply With Quote
Old 06-21-2017, 10:52 PM   #12
RocketcarX
RocketcarX's Avatar
Default
I have had 2 FWD Ford manual transmissions fail using RP within a suspect time period. Both grenade'd.
Once I started looking into them, the negative feed back I've seen in oil studies vs. mobil 1 rules RP out for me.
__________________
Old 06-23-2017, 09:35 AM   #13
Yoyo1
stangester
Yoyo1's Avatar
Default
Interesting. Thanks for all the input. I decided to trash RP go with Mobile 1 syn ATF.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Ad Management plugin by RedTyger
