SEMA 2014 Front End Conversion
o2sys
NY/NJ
When is the fender expected to be released for public consumption?!
DRock
They have been sent out o be made/finished.
It took some time to get everything perfect but i got there.
DRock
WIth an OEM hood on the car.
Turns out I never took a pic after messing with it further. Here is the best I have
dougie b
crap.....there goes my budget for everything else I wanted....when these are available I will definitely be swapping front ends
gray1622
Norman, OK.
What all parts do you have to swap to make this work? I saw one thread were the guy cut away part of the front end then welded on 11+ one.
DRock
Back on the car. It was raining and poke on those throws water EVERYWHERE!
v8venomgt
round lake, il
great looking car. did you mention once before a 2013 gt500 style grill is also being made for the 07-09 gt500s?
5iv
Homo 3.7 and 4.0 owner
Jonesboro, AR
Drock said just drilling holes and trimming the headlight buckets. No core support swaps needed.
retfr8flyr
The Old One
Providence Forge, VA
Car looks great and you should be very prod of all your hard work. I am very interested in doing this swap on my car, when the fenders become available. Are you going to put together a kit with what's needed for the swap, or just market the fenders?
DRock
I could do a full write up but shark tales already did it and that's pretty much all it takes. And a lot of patience ha. The only non oem part that you need is the fenders. Everything else if for a or is off a 2010-2012
retfr8flyr
The Old One
I thought shark tails replaced the whole front support and everything else from the 2010-2012. It was stated earlier that the 2005-2009 front support and some mods to the lights would work. Will it require everything from the 2009-2012 front end for the swap?
DRock
I literally did nothing more then cut out the headligh buckets and drill a couple holes. If you want to get real fancy the whole support can be had around $200 and you cant cut your old one out and replace it for perfect fitment first time. Or budget minded and start cutting on the car.
You need:
Hood off of or for 2010-2012
Front bumper off of or for 2010-2012
Grill off of or for 2010-2012
(2) Bumper brackets
Headlights off of or for 2010-2012
Bumper lights off of or for 2010-2012
AND these fenders.
All the bulbs are the same for the halogen headlights and running light 05-2012.
DRock
The 13/14 parts are not compatible with the fenders?
They are. Just getting everything to do a 13/14 swap is gonna be a bit more difficult. THe upper mount for the bumper wont work or well could work just more drilling/cutting of the core support. If you wanted to go that route i would recommend doing the whole core support at that point.
