Breather catch can (battery tray)
PNR Welding
Hammonton, NJ
We make these also.
This is the R&D version.
Powdercoating is available
There is a baffle inside that will prevent anything from coming out but pressure.
-10an fitting (2)
PNR Welding
Hammonton, NJ
Just the tank, brass breather, breather filter and two 10an male fittings welded onto it.
10an hose fit over the driver side valve over barb.
The passenger valve cover barb needs a spacer for the 10an hose to go over.
I can put together something for it to all work.
ModdedMach
Detailer of shiny things.
hell yes. Thats clean. Im considering this or a peterson setup.
Is it internally baffled?
PNR Welding
Hammonton, NJ
That is the first one that had to be modified a little so it doesn't look as good.
I plan to make another for my car before track season.
But you get the idea
